Thread: Oil light flashes and beeps
  1. Exclamation Oil light flashes and beeps
    Dec 2009
    newcastle upon tyne
    Hi guys, my girlfriend has a v reg 1.4 16v golf and when you start the car and give it a few revs, the oil light flashes and it starts to beep. I have checked the obvious and the oil level is fine.
    If anybody could shine any light on the situation it would be much appreciated
  2. Re: Oil light flashes and beeps
    Dec 2007
    crawley, west sussex
    is it the yellow warning light or is it the red stop now return to workshop warning light? if it's the red one, don't drive it anymore & get it towed to garage before you kill the engine, could be just a sensor, oil pump or blockage starving the engine of oil.
  3. Re: Oil light flashes and beeps
    Dec 2009
    newcastle upon tyne
    Quote Originally Posted by glen poole View Post
    it is the red oil can flashes up, it is fine on idle but as soon as you rev over 3000 it flashes up, beebs, then goes off after a few seconds when it returns to idle.
  4. Re: Oil light flashes and beeps
    May 2007
    i think you will find that is a blocked oil pick up, soon as you put the engine under stress by reving it, it can not supply enough oil and the pressure drops,
    i would stop driving it, get it picked up and taken to the garage, so tey can have a look and clean stuff out.
  5. Re: Oil light flashes and beeps
    Dec 2009
    newcastle upon tyne
    Problem solved!
    I had a look into the problem today, took the sensor out and cleaned the wire connection and has seemed to have solved the problem, wiring must have been making a bad connection to the sensor.
    Thanks for your advice lads
  1. '97 cabriolet brake warning light
    By john sharples in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 30-08-2009, 09:39 PM
  2. Help with auto scan
    By PETER G in forum VCDS - General Questions
    Last Post: 17-04-2009, 12:58 PM
  3. Temperature Warning problem (with spares need)
    By nocoordination in forum Audi A3 - Archive Topics
    Last Post: 06-02-2008, 02:56 PM
  4. 3 beeps with ignition
    By bromine in forum Archive posts
    Last Post: 09-12-2007, 08:28 PM
  5. A4 Brake System Warning Light
    By lastyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2007, 12:38 PM
