Thread: Loose Door Handle
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
  1. Re: Loose Door Handle
    #21
    Quote Originally Posted by Piez View Post
    I have 04 1.8T and over the last few weeks I've noticed the outside drivers door handle is getting looser. Compared to the other handles on the car it doesn't have the same stiffness of resistance when you open it and it rattles sometimes when you shut the door.
    Has anyone else had this problem and if so how did you get it fixed?
    hi there,i've had the same problem with my door handle!its really easy to fix,all you have to do is get yourself a long flat thin screwdriver,put some tape around the blade(this is just to protect your paintwork).hold the door handle in the open position,and look down the back of it where you will see a stainless steel clip.now with the door handle open slid your screwdriver in from the front of the handle and carefully slide the clip back into position,job done!!!!!!!
  2. Re: Loose Door Handle
    #22
    Mar 2006
    Quote Originally Posted by The Glove View Post
    Yeah Cheers Matt200sx, problem solved
    Took some pic's as I did it as the handle cover fell off in the process
    Pic 1 is with no cover and shows the clip at the top of the handle which needs to be pushed towards the back of the car.
    The others show me doing this with a card - with and without handle cover (like you Dillion A4 didn't what to scratch paint with screwdriver)
    Hi thanks, without the photos i would have never found the clip. I didnt realise it could be accessed from the top. An anoying rattle now cured.
    regards Paul
  3. Re: Loose Door Handle
    #23
    Jul 2007
    somerset
    8 Post(s)
    Just tightened up my door handles, it would seem that with the passenger one you need to slide the stainless clip towards the FRONT of the car, and the drivers side towards the REAR of the car.
    If you remove the handle trims completely, you can bend out the tabs on the stainless steel slider clip with a small screwdriver to make the fit more snug. Using an old credit card is an ideal tool as it will not scratch your paintwork.
  4. Re: Loose Door Handle
    #24
    Jun 2009
    Belfast
    Good work, this was bugging the crap out of me and am glad you guys found an easy fix. Just tapped both clips towards the centre on my 05 A4 and it worked a treat.
  5. Re: Loose Door Handle
    #25
    Aug 2007
    Newport, Wales
    7 Post(s)
    I tightened up my clip using the credit-card hint this weekend.
    I'd just like to say thanks again for the info in this thread - my car door now slams with the trademark Audi quality "thud" as opposed to a Fiat metalic clunk
    A hint to anybody else doing the repair: I initially thought there were two clips that both needed pushing towards the centre of the handle, but there is just one long clip that needs pushing in the direction of the back of the car.
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  6. Re: Loose Door Handle
    #26
    Doctor46 Guest
    Quote Originally Posted by toff View Post
    Al.
    Ditto!!!
    Got half way through reading this thread and popped outside to try it. Top tip folks thanks.
  7. Re: Loose Door Handle
    #27
    May 2008
    Brilliant thanks for the pictures even managed it in the dark!!!
  8. Re: Loose Door Handle
    #28
    Jan 2009
    Ireland
    I just did this, hopefully the thing stays on!
    Thanks very much
    2005 Audi A4 2.0 TDI S-Line I need to start the mods now
  9. Re: Loose Door Handle
    #29
    May 2010
    Lerwick Scotland
    My first foray onto the Forum and I find the solution to the door handle problem, thankyou for the help!
  10. Re: Loose Door Handle
    #30
    Apr 2010
    United Kingdom
    This has been bugging me for weeks and i fixed it in 30 seconds flat in the dark with a credit card Thanks guys.
  1. Inside door grab handle
    By redadair in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-02-2008, 08:43 PM
  2. golf mk4 door handle
    By valley rower in forum Golf MK4 - 1999 - 2004
    Last Post: 03-06-2007, 12:40 PM
  3. Drivers exterior door handle problem
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-04-2007, 09:24 AM
  4. Passenger Door Handle
    By neilc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-04-2007, 10:07 PM
  5. A4 avant 2.5 tdi quatro steering, air con, door handle
    By tkboy in forum Chat - Completely Off Topic
    Last Post: 20-11-2006, 03:05 PM
