Thread: fault codes on a 2.0s petrol 2001
Results 1 to 8 of 8
  1. fault codes on a 2.0s petrol 2001
    Dec 2009
    liverpool uk
    i think its the 115bhp version
    it started as a slight misfire which got worse over a few weeks
    now when i come to lights the revs drop down to about 500 then regain themselves to about 8 or 9 but the misfire is still there
    it seems ok when driving normally but about a week ago the light came on
    i scanned it on a solus and it gave all of these codes
    17978 engine ecu blocked (p1570) error occurs intermittent
    16555 fuel trim (bank 1) system too lean (p0171) error occurs intermittent
    17831 secondary air injection system (bank 1) flow too low (p1423) error occurs intermittent
    16556 fuel trim (bank 1) system too rich (p0172) error occurs intermittent
    17549 load registration unlikely value (p1141)
    i cleared the codes and it ran fine for about 10 miles then it started to dip again and within another 5-10 miles the light came back on
    no doubt the same codes again
    does anyone know what these codes mean?
    thanx
    carl
  2. Re: fault codes on a 2.0s petrol 2001
    Dec 2009
    liverpool uk
    guess not
  3. Re: fault codes on a 2.0s petrol 2001
    Oct 2005
    Quote Originally Posted by fz911 View Post
    http://wiki.ross-tech.com/index.php/17978/P1570
    http://wiki.ross-tech.com/index.php/16555/P0171/000369
    http://wiki.ross-tech.com/index.php/17831/P1423/005155
    http://wiki.ross-tech.com/index.php/16556/P0172
    http://wiki.ross-tech.com/index.php/17549/P1141/004417
    Cold boot the car as described in the first link as the other codes aren't immo related.
    It all points to a vacuum leak imho.
  4. Re: fault codes on a 2.0s petrol 2001
    131 Post(s)
    1978 Post(s)
    Which codes came back? These are prone to split crankcase vent pipes which as said by mycarsavw points to an air leak after the AMM.
  5. Re: fault codes on a 2.0s petrol 2001
    Oct 2005
    Mine was a split hose in the SAP system - directly behind the engine, foreward of the firewall.
  6. Re: fault codes on a 2.0s petrol 2001
    Dec 2009
    liverpool uk
    thanx for the input/info, i didnt get chance to get back to rescan, ill head up there monday to see whats came back, incidentally i started having another problem shortly afterwards, probably not related but its indirectly gave me some info, my battery is really weak, sometimes if i leave the parking light on or if i leave the lights on for a minute or so, it will die and i cant start it, well the mrs went out in it and she left the indicator/parking light on when she went into a shop, came out and it wouldnt start, i arrived and jump started it, the light reset, no more engine management light, its been 4 days and 250 miles, it still idles funny but the light hasnt returned, but after that dead battery incident my central locking wouldnt work properley
    the button would only open and close the drivers door, usually when its pressed it first locks all doors and then deadlocks them, it was only locking them on the first click and when opening, it only opened drivers door, this was happening for 2 days until my battery died again, i started it with a booster pack and after that the central locking worked fine again,
    i was just thinking if maybe the immobiliser/central locking problem is setting off one of the codes, or maybe causing a drain on the system producing strange fault codes
    just a thought, and probably way off but still...
    anyway, tomorrow ill have a look see if i can find any dodgy vacuum pipes etc, and failing that ill be back to rescan on monday, whatever info i get ill post up here,
    thanx again guys, i was lost for a while on the codes, the solus book doesnt cover some of the codes i got
    luckily you knew where to look
  7. Re: fault codes on a 2.0s petrol 2001
    Dec 2009
    I'd say your battery is shot. Get a new one and reset the fault codes, and then go from there. Thats probably why your central locking etc was playing up.
    Wouldn't have thought it would account for your other problems, but you never know.
    2002 Passat PD 130 TDI Sport Estate
    2003 Golf GT TDI PD 130
  8. Re: fault codes on a 2.0s petrol 2001
    Dec 2009
    liverpool uk
    yeah definately need a battery now, it let me down big time this morning, had to jump it off her car, ive done some digging and the crap battery could be causing the
    new battery as u say, and then rescan
    thanx
    carl
  1. Problem with Advanced Key & One-Touch Memory
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 29-11-2013, 09:51 AM
  2. Passat fault codes
    By bigiveaudi in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-08-2009, 11:10 PM
  3. Fault Codes
    By rayTTsmith in forum TT - 8N Forum - 1998 - 2006
    Last Post: 07-08-2009, 06:26 AM
  4. VAG COM Fault codes
    By wcb in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-08-2009, 08:32 PM
  5. Bora New Cat / Fault Codes
    By piggy99 in forum Bora - 1998 - 2005
    Last Post: 29-02-2008, 06:42 PM
