Thread: Banging from Gearbox?
  1. Banging from Gearbox?
    May 2007
    Little Houghton, Barnsley, United Kingdom, United Kingdom
    Really needing help with my Golf mk gti anniversary PD ARL
    When warming up my engine there a loud nasty banging sound coming from the bell housing/gear box casing, coming not timed but a weird banging sound
    Once the engine has warmed theres no sound?
  2. Re: Banging from Gearbox?
    Mar 2007
    U-96
    Quote Originally Posted by e6m6a6 View Post
    Possibly the DMF, which is preferable to the cams.
    Check to see whether depressing the clutch pedal reduces the noise.
    See;
    Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
  3. Re: Banging from Gearbox?
    May 2007
    Thankx for you help, going to be an exspensive fix!
  4. Re: Banging from Gearbox?
    May 2007
    http://www.eurocarparts.com/ecp/k/flywheel/p/Car-Parts
    Found some prices...would a solid conversion kit be worth it? Does it change anything?
  5. Re: Banging from Gearbox?
    Oct 2007
    Weshhht of Ireland....
    While a solid conversion sounds like a better idea, it also comes with its drawbacks. The biggest being tranmission of noise into the car. DMF's are put into modern cars to "absorb" noise and shock loads in drivetrains of moderns cars and to reduce stress caused to components of the drivetrain from ever increasing horsepower ratings of engines today. So fitting a SMF or solid flywheel will no doubt eliminate the worry of having it pack up but you will be faced with more noise and vibration inside the car and its something you probably don't want if you use the car as an everyday driver to and from work etc.
    HTH
    '99 B5 S4 ---------Gone
    '05 Leon PD150 --Not really gone
    '01 B5 RS4 -------Gone
    '05 Leon PD150 --Went but came back again
  6. Re: Banging from Gearbox?
    May 2007
    think ill stick to the DMF!
    Will it cause any damage if not done straight away?
    If not ill leave it untill i need a new clutch
  1. VW Sharan VR6 (99) Auto gearbox problem
    By bluemozzer in forum Touran - Sharan - Caravelle
    Last Post: 01-01-2013, 11:53 AM
  2. Please Help Gaerbox Breakdown??
    By guido.minciotti in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-10-2009, 10:56 AM
  3. Help! A4 gearbox nightmare!
    By Patsy666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2008, 02:48 PM
  4. Help! A4 multitronic gearbox problems!
    Last Post: 18-04-2008, 10:18 PM
  5. Replies: 0
    Last Post: 22-12-2007, 03:29 PM
