Thread: Fuel Tank + Reserve Fuel
Results 1 to 10 of 12
  1. Fuel Tank + Reserve Fuel
    Nov 2009
    Peterborough
    I just filled up my golf and it drank 55.19Ls
    I understand the reserve tank is 7Litres but is that included in the 55L tank or excluded?
    Range shows 410Miles!....
  2. Re: Fuel Tank + Reserve Fuel
    May 2009
    Edinburgh
    Do cars actually have a reserve tank? I had just assumed that when the light came on it meant that I was down to my last gallon or whatever, not that it was now feeding from a reserve tank. Or is it just an incorrectly used term?
  3. Re: Fuel Tank + Reserve Fuel
    Jul 2009
    Hertfordshire, UK
    That was my understanding (or impression) as well.
    Golf VI GT TSI 1.4 160PS, 18" Vancouver alloys, air conditioning '2Zone', luxury pack, winter pack, RCD 510 with Dynaudio, parking sensors
  4. Re: Fuel Tank + Reserve Fuel
    South London. UK
    Quote Originally Posted by SebbyMK6 View Post
    Yes, of course. There is no actual reserve tank but just a warning that you're down to your last 7 litres or whatever the actual value is. When down to this amount you get the warning on the display - as simple as that.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  5. Re: Fuel Tank + Reserve Fuel
    Dec 2006
    Quote Originally Posted by illestjt View Post
    its Included..
    The tank is 55 litres, plus the neck of the filling pipe.. so maybe an extra few litres..
  6. Re: Fuel Tank + Reserve Fuel
    Nov 2008
    Aberdeen
    I've driven my Golf to below the red bar... it still had 2 liters left at the gas station. But it all depends on your driving habits! I was doing 40-50 mph on a coastal route and turned everything off when the range went to zero. MPG was in the high 30's (2 persons, some luggage).
  7. Re: Fuel Tank + Reserve Fuel
    South London. UK
    Quote Originally Posted by slo007 View Post
    Apparently it's not a good idea to run your fuel tank that low as you can introduce all sorts of nasties into your fuel lines - I would have thought so, anyway.
  8. Re: Fuel Tank + Reserve Fuel
    May 2009
    Edinburgh
    Quote Originally Posted by HHGTTG View Post
    See, I can't see how there is any truth in that either (and I'm not calling you a liar btw ). Petrol is a liquid, so it will slosh about when you move, meaning that any rubbish is going to be continually moved anyway. Also, when you start your car in the morning, this rubbish will have settled to the bottom, so again will probably be sucked down the fuel line.
    This is of course assuming there is any rubbish in the tank. But are they not all plastic, or plastic based anyway? So where is this rubbish coming from? Also, I'm assuming there are filters somewhere down the line as well?
    So, I just don't see how there is any truth in this statement. I could be totally wrong however, so if someone else knows for certain, please, educate me lol.
  9. Re: Fuel Tank + Reserve Fuel
    Canada
    Running fuel low used to be a no no on older cars, no filter etc. But tanks are plastic now and all have fuel filters.
    The big no no is that on diesel cars that they use the fule to lubricate the pump etc so running out of fuel can cause high wear to the pump while it primes...also you look a right numpty running out of fuel
  10. Re: Fuel Tank + Reserve Fuel
    Dec 2006
    Quote Originally Posted by SC03OTT View Post
    Many years ago this was a problem with the metal fuel tanks rusting from the inside out, therefore many metal particals ended up in the bottom of the tank, hence where the idea came from..
    As with all new cars having a plastic fuel tank, this is no longer the case.
    The problem you have now with running the car next to ZERO, is the "crap" which is in the Fuel stations fuel tanks which get pumped into your cars, yes it should be filtered, but i think they is always a chance of something going wrong..
    One further point is, its not good to run a fuel pump with no fuel running through it,
    Rick
  1. Replies: 2
    Last Post: 24-11-2010, 11:35 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Please Help. Non Start - No Fuel Flow.
    By wallis22 in forum Archive posts
    Last Post: 13-01-2008, 03:10 PM
  4. The way we talk about fuel and why it is so confusing.
    By Ben in forum Chat - Anything with wheels
    Last Post: 02-01-2008, 10:50 PM
  5. Newbie - first post- looking to buy!
    By woza in forum Golf MK4 - 1999 - 2004
    Last Post: 05-03-2007, 01:41 AM
