Thread: Water temperature
Results 1 to 10 of 12
  1. Water temperature
    Jan 2009
    I have a problem with the water temperature at the moment, it used to sit just under 90 all the time. Now it drops off to nothing and then ocassionally will come back and read just under 90 or sometimes 70-80 - other times nothing. I appreciate it could be a dodgey connection or a faulty sensor (not sure which is kost likely) but don't know where the sensor is to have a look!!
    Can anyone steer me in the right direction???
  2. Re: Water temperature
    HomerSimpson Guest
    Hi Andy,
    Looks like you are having the same problem as me, sounds like the sensor is faulty. It is located I believe on the drivers side somewhere near the bottom of the engine bay, I am sure there is something on the forum detailing how to change it, I think you have to remove the cover under the engine to get access.
  3. Re: Water temperature
    Quote Originally Posted by andy24uk View Post
    I have exactly the same problem so anyone could give us some info on where to find it and change it would be great!
    2000 A4 1.9 TDI (115)
  4. Smile Re: Water temperature
    May 2007
    St Ives Cornwall
    I had the very same problem and was advised to change thermostate by a forum member and temp came straight back upto 90 and has remained there.... Maybe a cheraper fix than a sensor...
    Jabez
  5. Re: Water temperature
    Jul 2008
    stoke on trent
    if cars not getting up to 90 then try thermostat
    if temp gauge is erratic try sender
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  6. Re: Water temperature
    coventry
    i have the same temp stays below 60 all the way to work (17 miles) but if im not moving and car has been on a while it will get upto 90 not sure if i have a fault or not?
    can anyone tell me where thermostat is
    masny thanks in advance
  7. Re: Water temperature
    Mine does reach 90 sometimes and if I have the heater on it starts to drop below 90 and if I am idle it also drops.
  8. Re: Water temperature
    Dec 2009
    wisbech
    I had a markone A4 for 4 years and now have had my mark two for 6 years and both cars temp was always on 90 degrees, was always amazed how consistant this was!
  9. Re: Water temperature
    May 2008
    Lowestoft suffolk - not far from Norwich
    I have the same issue, I had mine remapped in July and he told me the thermostat had packed up, causing the engine to always run cold? Mines due to be replaced next week, will update...
  10. Re: Water temperature
    Newcastle upon Tyne, England.
    Mine's the same too. New thermostats are less than £6 from Euro Car Parts, can anyone tell me where the stat is in the engine bay and if I need to drain the coolant to change the little fella?
    Cheers.
  1. Please Help coolant system circulation
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-02-2010, 08:13 PM
  2. Numerous Details on Digital Air Con Display
    By sooty in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 08:09 AM
  3. Climatronic Diagnostics
    By milenia in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2007, 10:17 AM
  4. Water Temperature Indicator
    By padrag_king in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-07-2007, 05:27 AM
  5. VOLKSWAGEN REVEALS HIGH TEMPERATURE FUEL CELL TECHNOLOGY
    Last Post: 01-11-2006, 09:55 PM
