Thread: warning lights reset?
  1. warning lights reset?
    Aug 2008
    this might seem a silly question to those with experience, but I can't find a specific reference in the forums.
    When you get a dashboard warning light, (in this case ESP), will the light go if the fault is cleared, or does it need resetting by diagnostic tools?
    Ive got a golf v 1.9 tdi on a 55 plate.
    thanks in anticipation of a reply
  2. Re: warning lights reset?
    Mar 2009
    staffs
    you can get the light turned off and cleared ,not using a vag com.i done this with a passat i had a few years back, but if you do not fix the fault thats causing the light to come on,it will keep flagging back up this used to last for about 2 weeks then the light would come back on.
  3. Re: warning lights reset?
    Aug 2008
    thanks to nc7503 for response, but you don't actually tell me if the light will go automatically if the fault is cleared.
  4. Re: warning lights reset?
    Pembrokeshire
    22 Post(s)
    it might do, depends what the fault is.
  5. Re: warning lights reset?
    Chester-le-Street, United Kingdom
    Quote Originally Posted by zillfish View Post
    what light have you got on?
    is it in the dash pod?
    is it flashing? or is it constant?
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  6. Re: warning lights reset?
    Aug 2008
    Hi stewy,
    the warning light I have is a constant esp warning in the dash, and also shows "esp off" at the switch in the centre console.
    I've researched this and other forums, so I know some of the possible causes, but the day after the light came on I had a puncture and this can unbalance the system triggering the alarm. I know I'm grasping at straws, but I keep hoping it isn't the abs pump module.
    cheers, zillfish
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. More warning lights on the dash arghhhh (pic included) :( wish I never started now!
    By Killer passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-10-2009, 10:04 PM
  3. Please Help warning lights due to water getting in
    By dave960w in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-06-2009, 08:01 PM
  4. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
