Thread: a4 1.9 tdi
Results 1 to 10 of 12
  1. a4 1.9 tdi
    Jun 2009
    uk
    yet another fault with my Audi a4 1.9 tdi started from cold in morning was OK after i drove it for like 30 seconds car went into limp mode and then in a Que car was shaking like mad looked like it was going to blow up.
    i had shut the engine off and started it again like 3 times to get car out of limp mode.
    anyone know what it could be i had car on computer before it shows error code.
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    anyone know what the fault is..
    thanks
  2. Re: a4 1.9 tdi
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Could be a split/loose charge air hoses,N75 solenoid for boost control,or vacuum pipes split/leaking.Or,Vanes sticking in Turbo.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: a4 1.9 tdi
    Oct 2009
    Redcar
    where is the n75 on a tdi engine please? :S
  4. Re: a4 1.9 tdi
    HomerSimpson Guest
    Hi Cusford.
    The N75 is located at the front of the engine block, drivers side just behind the electric fan. It has three quarter inch hoses and an electrical connection. It is also mounted on a small bracket.
    Hope this helps you to find it.
  5. Re: a4 1.9 tdi
    Jun 2009
    uk
    has anyone got a picture of the n75 valve??
  6. Re: a4 1.9 tdi
    HomerSimpson Guest
    Easiest thing to do is type "N75" into the search box on ebay, this usually brings up a few and will give you an idea as to what to look for.
  7. Re: a4 1.9 tdi
    Jun 2009
    uk
    had aa guy come out tday was very helpfull put it on his computer nothing was coming up it didnt even bring up the boost pressure fault up.
    he checked all the hoses and pipes all were ok no splits their was some oil on the intercooler which i think is from the turbo but its dried on so it is a slow leak some oil under the egr valve again its a bit dry so a slow leak.
    he took 1 of the turbo hoses off and it was filled with black gunk and said all hoses going to turbo need a good clean my turbo is on it way out i think.
    but when the car is warm its ok like normal.
  8. Re: a4 1.9 tdi
    Jun 2009
    uk
    i changed the maf on it will see what happens in the morning when its cold.
  9. Re: a4 1.9 tdi
    Jun 2009
    uk
    started it from cold this morning put my foot down was OK after 5 seconds straight into limp mode and shaking like mad with no power and smoking looks like i waisted my money on the maf cost me 65.00.
    what else could it be this is really getting annoying now.
  10. Re: a4 1.9 tdi
    Jun 2009
    uk
    bump anyone...
  1. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  2. 1.9 TDi help.....
    By Estoril Ben in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2007, 10:52 AM
  3. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
