Thread: Low Oil Pressure Injector Failure message
Results 1 to 8 of 8
  1. Low Oil Pressure Injector Failure message
    Mar 2008
    Hi Everyone,
    2005 Estate has given this warning after being run on very low oil - not by me, by someone I lent the car to.
    'Low Oil Pressure Injector Failure was the dignostic message.
    After cleardown, turn on electrics, then Red Light, Low oil pressure - STOP.
    Then the same Diagnostic message.
    The engine will turn over, but sounds like it has reduced compression and will not start.
    Is it @@@gerred??
    Any advice - apart from don't lend your car to idiots - gratefully received.
    Thanks in advance.
    Cheers,
    Paul
  2. Re: Low Oil Pressure Injector Failure message
    Afraid the diagnostics don't look promising,but the first thing you will need to check is the oil pressure
  3. Re: Low Oil Pressure Injector Failure message
    Mar 2008
    Thanks for the feedback.
    Is that an easy thing to do - or is there a thread I could check that you know of - I can't find it if there is,
    Cheers,
    Paul
  4. Re: Low Oil Pressure Injector Failure message
    You will need to remove the oil pressure switch and attach an oil pressure gauge
  5. Re: Low Oil Pressure Injector Failure message
    Mar 2008
    Thank You.
    Would anyone know what sort of pressure is considered OK??
    Cheers,
    Paul
  6. Re: Low Oil Pressure Injector Failure message
    At 2000 rpm and an oil temperature of 80 °C the oil pressure should be at least 2.0 bar.
  7. Re: Low Oil Pressure Injector Failure message
    Mar 2008
    Thanks for the info, the problem I have will be starting it to test it!!
    It sounds like the compression is low as it spins.
    Oh, Oh!!
    Cheers,
    Paul
  8. Re: Low Oil Pressure Injector Failure message
    I think the reason for no compression,is that the manifold flap motor is not opening,i'am not 100% sure but i think, if there is no oil pressure,the ECU will not open the flap.However even turning the engine by the starter you should get a certain reading.
  1. Please Help Oil pressure light
    By jimmayo in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 22-10-2009, 12:18 AM
  2. Basic Oil advice from Opie Oils
    By oilman in forum Chat - Completely Off Topic
    Last Post: 09-09-2009, 03:11 PM
  3. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
