Thread: Problem with cruise control
  1. Problem with cruise control
    Mar 2008
    Preston
    fitted a retro fit cruise control to my vw golf mk4 year 2001. GT TDi 115 PD.
    cruise control does not work, its been activated through vag-com and when you turn it on the green light comes on but speed cant be set. also after fitting the cruise control and putting everything together i discovered the traction control constantly on. everything was fine before, any one got any ideas!!
  2. Re: Problem with cruise control
    Southampton, UK.
    I would double check the wiring you installed. Also, just incase you don't know, the set speed is cancelled by a switch on the clutch and brake pedals. If either are faulty, you'll not be able to set a speed. But as you have a different problem since you installed it, I think it must be something there. Have any codes been thrown up?
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  3. Re: Problem with cruise control
    nottinghamshire
    my cc is standard fitted but i can get it to set a speed either, the light comes on but doesnt work..
  4. Re: Problem with cruise control
    Mar 2008
    Preston
    thanks for the info. i solved the traction control problem. the light was on because after removing the steering wheel i did not put it on in the exact position e.g. the would take one and half turns on steering wheen to the right and two and a half turns to lock it to left. as soon as i took it back off and put it on the right way the traction control light went off but cruise control still never worked.
    Then i called a friend and we ran the car on vag-com and found the clutch pedal switch was faulty!! i got a new one from dealer for £12 and whooopie it works now.
  5. Re: Problem with cruise control
    Mar 2008
    Preston
    my advice to you is if the light comes on and speed cant be set more than likely your clutch pedal switch or break pedal switch is faulty. mine did same and i changed clutch pedal switch and now it works perfect!! the reason speed cant be set is becasue the switch is telling the car the clutch or break is contantly down, hence this is why you see people driving with their rear break lights on contantly lol....
  1. central locking problem, not control module!
    By novadan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-03-2017, 05:45 PM
  2. How To DIS AND CRUISE RETRO FIT b6+b7
  3. Quick cruise control related question :-)
    By craig2210 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-11-2009, 03:07 PM
  4. AWX A6 Cruise control..
    By davebp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-07-2009, 11:08 AM
  5. Adaptive cruise control - Is it available?
    By WiiJeff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-09-2007, 06:58 PM
