Thread: VAG 2.0T Fsi Atmospheric dump valve
Results 1 to 10 of 11
  1. VAG 2.0T Fsi Atmospheric dump valve
    Sep 2009
    manchester
    hi has anyone used one of these on there cars and is it worth buying thanks
  2. Re: VAG 2.0T Fsi Atmospheric dump valve
    Mansfield, UK
    No and no.
    The system is designed to be recirculative and by fitting an atmospheric valve you are losing all that valuable boost which can be reused to reduce turbo lag. They're a total waste of money.
  3. Re: VAG 2.0T Fsi Atmospheric dump valve
    Sep 2009
    manchester
    thanks for the quick reply, i didnt know much about them
  4. Re: VAG 2.0T Fsi Atmospheric dump valve
    Mansfield, UK
    No problem
    I would suggest changing your diverter valve though, as cars with original diaphragm ones are almost always split when people come to me for tuning. For the A3/TT/Golf/Octavia there's a new one (revision D) which is a piston type which is MUCH improved, I'm sure there's one for the A4/A6 too but I don't know the part number off the top of my head.
  5. Re: VAG 2.0T Fsi Atmospheric dump valve
    Aug 2008
  6. Re: VAG 2.0T Fsi Atmospheric dump valve
    Nov 2008
    The revision 'D' is the same on the A4/A6, as it is on transverse engines
    Part number 06H145710D
    £46.45 inc vat from your local dealer. (That can be VW / Audi /Skoda or Seat - it maketh no difference - its used widely on all brands)
    As Shark says its much improved. Its the current version fitted at the factory to most new 2.0tfsi engines - Hell, its even fitted to the 2.5 tfsi 5cyl TTRS (340ps)
    Bit of a pain to change on the A4 as its on the front of the engine and the radiator fan is only a couple of inches away, not leaving much room!
    2006 A4 saloon 2.0T S-Line Special Edition.
    Mauritius Blue - Xenons, Bose, Heated Valcona, Cruise, Colour DIS, Ipod, Revo. Big Smile.
  7. Re: VAG 2.0T Fsi Atmospheric dump valve
    Jul 2007
    Gloucester
    NO issues with fitting the Forge blow off spacer , works well , no check engine lights , money back if your not 100% happy
  8. Re: VAG 2.0T Fsi Atmospheric dump valve
    Dec 2007
    forge all the way not very loud tho or theres the adjustable and the vacuum DV
  9. Re: VAG 2.0T Fsi Atmospheric dump valve
    Sep 2009
    manchester
    thanks for your replys
  10. Re: VAG 2.0T Fsi Atmospheric dump valve
    Jan 2010
    Leicester England
    Is there an easy way to tell if the original diaphragm is split?
    A6 3.0 SE Quattro
  1. dump valve? 2.0T
    By Nicks in forum Golf MK5 - 2004 - 2009
    Last Post: 25-08-2008, 12:36 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Dump valve or no dump valve?
    By Richie84 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-05-2008, 11:34 PM
  4. replacing atmospheric dump valve with re-circ dump valve
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-02-2007, 10:27 PM
  5. Audi Injects Even More FSI Efficiency Into 2007 Range
    Last Post: 04-12-2006, 08:06 PM
