Thread: vag-com not connecting to cable
Hybrid View
  1. vag-com not connecting to cable
    armagan Guest
    Hi can someone help?
    I just bought a vag com cable with an ODB2 connector off ebay,
    (this one http://cgi.ebay.co.uk/ws/eBayISAPI.d..._promot_widget)
    and am trying to connect it to vagcom 409.1, on my laptop. Once the drivers installed, it has installed as a serial port to com 2.
    trouble is when I start vag com and do the test, it says port status is ok but "interface not found." I did the LED test as well that performs fine but the first test does not seem to connect.
    I even had the car running during the tests, the cable has a light on the adapter which is not on (should it be?) I have double and triple checked its securely plugged into my B5 passat (99 model)
    any advice/ideas appreciated
    cheers,
    Jun 2006
    UK, Mids
    Did you install the driver for your cable (not Ross-Tech's own) and set it up in Device Manager as a COM Port and then choose the same COM port in VAG COM? (even though it is USB)
    Is it autonostics (they are that colour)?
    http://www.autonostics.com/pages.php?pageid=3
    Apr 2007
    I bough the same product off the same guy. It comes with a small CD which has drivers that you need to install on your laptop / PC.
    After that just test your COM ports. I think for me it works on COM Port 2. I got stuck on it for ages cause I was expecting it to work on the USB port.
    Feb 2007
    yea the led should light up b 4 its connected to your laptop anyway so think the mite be a prob wiv the cars connection
  1. cant get VAG COM to recognise my cable
    By ardasaliah in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-06-2007, 03:53 PM
  2. CD Changer cable
    By Fourbears in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2007, 11:23 PM
  3. Bonnet cable
    By arfsvdub in forum Passat - Archive Topics
    Last Post: 09-05-2007, 04:27 PM
  4. ABS cable
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2007, 04:11 PM
  5. Cable for use with VDS Pro
    By NickW in forum VCDS - General Questions
    Last Post: 10-04-2007, 04:28 PM
