Thread: Alarm....
  1. Alarm....
    Feb 2007
    kent
    Thought i would have a go at finding the siren, i've been told its just under the plastic the wiper arms come through on the bulkhead. I undid the nuts on the wiper arms and gave em a good yank and they didnt shift, i even put a screw driver underneath them to try and leaver them up, but no go, at this point i thought about using the crobar. Then i had an idear one of you people must have some idears before i get carried away and do some damage...... please
    7 Post(s)
    The dealers use a puller to get them off.
    Lots of WD40, time to soak and brute force is needed.
    Be very careful about using levers as you are levering against the plastic scuttle trim which sits directly on the windscreen.
    To much oomph and crack goes your window !
    I've found a large open ended spanner under the wiper arm using your other hand as a cushion to the screen whilst you lever the spanner on your hand hurts like hell but is quite effective.
    Good luck.
    Oct 2005
    Lutterworth
    The last one I removed came off after using a hammer and punch to drive alternate sides of the wiper-arm hub down on the shaft causing it to rock and break free..
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  4. Talking
    Feb 2007
    kent
    thanks people i'll give it a go if i get time tomorrow.
  1. A4 Alarm.
    By Woz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-07-2008, 11:22 PM
  2. A4 Alarm
    By Jimbo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-12-2007, 03:33 PM
  3. alarm a4
    By mary in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-12-2007, 01:08 PM
  4. alarm
    By blakey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-05-2007, 12:42 PM
  5. SDI alarm
    By udders71 in forum Polo - Derby - Lupo - Fox
    Last Post: 11-05-2007, 07:34 PM
