Thread: Which model to go for???
  1. Which model to go for???
    Dec 2009
    Wirral
    Hi everyone new to this forum.
    Looking to buy an A6 S Line around 06 facelift i think? Will be used as taxi and airport transfers and so on so need good mpg would love the 3.0tdi but obviously it has to be the 2.0tdi and has to be auto box aswell is there a certain type of box i should be looking for multi or tip i keep reading???
    Any other advice would be greatly appreciated.
  2. Re: Which model to go for???
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    If you go for the 2.0TDi your only gearbox options will be the 6-speed manual or the Multitronic CVT. There have been a few stories on here of Multitronic boxes failing on the earlier C5 A6s and B6 A4s, but there I don't recall seeing any on the later cars. Even so, it's definitely worth getting a warranty with your new purchase, and make sure it covers parts and labour for the Multitronic box!
    Otherwise, it's worth checking when the car last had a cambelt change, and also enquiring whether the water pump was replaced at the same time.
    Happy hunting!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: Which model to go for???
    Dec 2009
    Wirral
    Hi thanks for the reply, is there anything I should look for in particular? Looking around 50k to 70k?
  4. Re: Which model to go for???
    May 2009
    69 Post(s)
    Other than the cambelt/water pump being changed, check the clutch operates smoothly with no judder, look for condensation in the rear light clusters and peeling window switches on the driver's door. Obviously, check that everything works properly too. I'm sure others will be able to add extra stuff to look for based on their experiences...
    MF.
  5. Re: Which model to go for???
    Dec 2009
    Wirral
    Thanks again it would def be the automatic I would go for, that is the multitronic isn't it? Just have a bad left foot and can't use the clutch anymore.
  1. A5- Model Guides
    By blacksline in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 29-01-2010, 11:55 PM
  2. Imposing new r line model joins the tiguan range
    Last Post: 15-04-2009, 08:04 PM
  3. Imposing new r line model joins the tiguan range
  4. Greener New Generation Audi A3 Range Majors On Efficiency
    Last Post: 10-05-2008, 01:37 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
