Thread: Reverse lights INOP
  1. Reverse lights INOP
    May 2007
    Hello
    I now drive a Audi 80 K reg 2.0 100000
    I have checked the fuses and bulbs
    Reverse lights will not operate
    Is the a switch either on the Gearstick assembly or on the gearbox that I could change
    MOT due in 2 weeks
    Any help would be appreciated
    Feb 2006
    reverse lights not working wudnt fail mot....so no worries there. they dont check your reverse light on your mot. the reverse light swith is normally located on your gearbox....if you take the wiring connector off the switch and bridge the wires together with a paper clip the reverse light should come on....if it does then it is a reverse light switch faulty.
    May 2007
    thank you for the prompt reply
    Hi and welcome to the forum can't fault the above advice... let us know how you get on
    May 2007
    I found the switch on the gearbox but still no lights this morning
    Any advice would be appreciated
    Quote Originally Posted by waterman17 View Post
    did you do as suggested and bridge the connections, ie bypassing the switch to confirm the switch is faulty or not?
  1. No reverse light!...
    By Wessa in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-05-2007, 06:29 PM
  2. electric windows & elec mirrors inop fuse?
    By edespatch in forum Audi A4 - Archive Topics
    Last Post: 05-02-2007, 09:31 PM
  3. reverse lights not working
    By ljkbrierley in forum Audi A4 - Archive Topics
    Last Post: 16-01-2007, 05:01 PM
  4. HELP! NO REVERSE LIGHTS
    By ljkbrierley in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-12-2006, 06:12 PM
  5. MK3 GTi 8v Problems with reverse
    By Mowgs in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-08-2006, 10:45 AM
