Thread: MK5 Golf - water ingress through top of windscreen ?
Results 1 to 8 of 8
  1. MK5 Golf - water ingress through top of windscreen ?
    Dec 2009
    Brighton sussex
    My wife has a 2005 MK 5 1.6 FSI. When it rains overnight water is dripping down from the interior light / mirror thingy, and pooling in the gear lever gaiter, and dripping on the front seats when cornering.
    The windscreen is the original, car bought new by the father in law.
    Apart from filling the gap at the top of the screen with silicon bath sealant, has anyone got any ideas, or seen this before? Seems such an unlikely place to have a leak.
    Ta.
  2. Re: MK5 Golf - water ingress through top of windscreen ?
    I have seen it a few times before,the ideal thing to do is remove the windscreen and apply new sealant,which is a time consuming job,with the risk of breaking the sreen,when removing it.So the short cut is do do as you mentioned,but do not use silicon.
  3. Re: MK5 Golf - water ingress through top of windscreen ?
    Dec 2009
    Brighton sussex
    Quote Originally Posted by kenney View Post
    What would you suggest? I thought silicon would be OK, as there are no rubber bits up there for it to react with.
  4. Re: MK5 Golf - water ingress through top of windscreen ?
    Silicon is not a good idea to put on paint work.There are non silicon based windscreen sealants which can be purchased.
  5. Re: MK5 Golf - water ingress through top of windscreen ?
    xxx
    Last edited by kenney; 05-12-2009 at 02:40 PM. Reason: something wrong with the system same post came up twice
  6. Re: MK5 Golf - water ingress through top of windscreen ?
    Dec 2009
    Brighton sussex
    Thanks, I'll take a look in the local motorists shop, see whats available.
  7. Re: MK5 Golf - water ingress through top of windscreen ?
    Coventry
    had the same issue. Windscreen not fitted correctly. Only leaked in extreme conditions i.e pressure washer.
    Remedy- i was lucky enough to pick up a stone chip thus new windscreen the same day that i was fitting the towbar. The fitter could clearly locate the point of ingress.
  8. Re: MK5 Golf - water ingress through top of windscreen ?
    Dec 2009
    Brighton sussex
    Quote Originally Posted by Ben View Post
    I suspect this must be the case, the out-laws always garaged the car, so never noticed. I must say we've never had such a poorly built, low quality car. Where do VW get their "quality" image from? Not MKV Golfs that's for sure.
  1. Replies: 0
    Last Post: 03-07-2009, 07:48 PM
  2. Golf Mk4 2002 water leak
    By kevrev in forum Golf MK4 - 1999 - 2004
    Last Post: 05-01-2007, 12:08 AM
  3. New Golf Plus is show surprise at Bologna
    Last Post: 05-12-2004, 08:17 PM
  4. Golf grabs another top award
    Last Post: 31-07-2004, 08:29 PM
