Thread: Golf 1.8GL Starting problem
  1. Angry Golf 1.8GL Starting problem
    Feb 2006
    Golf wont start. Dash info lights flicker. Click on key turn. No engine turn over. Lights and equip show battery OK. Is this perhaps an earthing or a starter problem? Any ideas. Car is 1996 with 65K. Stuck at home.
    Feb 2006
    Waterloo, Belgium - where Napoleon fought and lost his last battle in 1815.
    Quote Originally Posted by rulleyman
    Could well be an earthing problem or a starter problem. If the lights don't go out when you turn and hold the starter key, then the battery probably is OK. The only earth point likely to cause this is the engine earth strap and that should be reasonably easy to check for a tight/clean contact. The starter motor could be more difficult to check out, particularly if you don't have a voltmeter or a 12volt test lamp. You can again check the main terminal for a good/clean contact but beyond that it is a matter or elimination.
  3. Smile 1.8GL Golf Starting problem
    Feb 2006
    Thanks Brian - AA got me going with a free homestart. I'd din't ahve that level of cover so was well impressed. The engineer was young but clued up. The problem was the battery which had 12V static but only 3 v cranking which apparently gives the flickering and buzzing instrument panel when the key is turned. It certainly had me foxed. New battery was fitted from van at £59 (probably not the cheapest but as a total cost and no towing to garage I was happy). CAR STARTS AND RUNS FINE.
    I like this 10 year old motor. Also have 52 1.4S Golf with A/C which I ordered and bought in France (UK spec) and a 79 Beetle cabriolet which I bought in 1990 in San Jose California.
    Feb 2006
    Pleased to hear you got it sorted.
  1. stalling/starting problem Mk3 Golf gti
    By mk3golfGti in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2008, 07:41 PM
  2. Starting Problem - Golf V5
    By SiJP in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2007, 01:43 PM
  3. Cold Starting Problem Golf 1.9d (95)
    By ak07oct in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-02-2007, 03:45 PM
  4. Cold Starting Problem Golf 1.9d (95)
    By ak07oct in forum Chat - Completely Off Topic
    Last Post: 21-12-2006, 08:41 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
