Thread: antifreeze
  1. antifreeze
    Jan 2009
    Manchester
    Hiyall, Do i have to put special antifreeze in my 2001 sharan tdi sport, or can i put a universal run of the mill in it, if it needs special antifreeze, anyone know where i can get it readily instead of vw. cheers
    Redex
  2. Re: antifreeze
    Mar 2007
    U-96
    Viv,
    Check the colour of your existing Antifreeze/Coolant.
    It is probably a Red/Pink/Purple colour, if so it is some form of G12 coolant and you should try and replace with a G12 conformant coolant (again normally pink/red/purple coloured).
    See this post for details of G12 conformant coolants;
    VW specifications for G12 compatible coolant, for more details on coolant.
    G12 conformant coolants should specify any of the following conformance levels;
    • TL VW 774D
    • TL VW 774F
    • TL VW 774G
    on the bottle/label.
    If your coolant is the G12 Red/purple/pink type you must avoid coolant specificationTL VW 774C which is BLUE G11 coolant and must not be mixed with G12.
    G12 conformant coolants (RPP) have a 5 year lifetime, whereas G11 coolant (blue) is typically rated to 2 year lifetimes.
    Apart from VW/Audi/Skoda/Seat dealers, G12 conformant coolant can also be purchased from;
    IIRC GSF's Febi coolant is the cheapest, if you only require 3 litres (2 x 1.5L bottles).
    Finally, G12 should optimally mixed at a 50:50 ratio of coolant to distilled/deionised water (i.e. avoid tap water).
    TR7
  1. a6 2.6 running temp +antifreeze
    By jimmpad in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-04-2009, 09:02 AM
  2. Correct antifreeze
    By lufftube in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2008, 04:20 PM
  3. non G12 coolant/antifreeze used - advice please
    By Tman08 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-01-2008, 02:32 PM
  4. Passat TDi antifreeze
    By warrtydog in forum Passat - Archive Topics
    Last Post: 22-01-2008, 12:27 PM
  5. Coolant in very cold weather (Alps)
    By richjthorpe in forum Chat - Completely Off Topic
    Last Post: 22-01-2007, 02:06 PM
