Thread: fan noise when accelerating????
Results 1 to 10 of 17
  1. fan noise when accelerating????
    May 2007
    Hi all new to this site right just brought an 02 plate Audi A4 1.9 TDi and all has been fine. BUT now i am noticing a fan like noise every time i accelerate. Aircon unit will be off and vents closed but will still hear this fan like noise coming from the dash area anyone any ideas please HELP
    Regards
    Dave
    Dec 2006
    Switch on the re-circulate function and redo the test, I've also had it, was merely the wind forcinging in via the vents. I normaly have the auto recirculate function on so it is not always there..
    Regards
    E
    Dec 2006
    Éire
    is this by any chance the sound of your turbo that you are hearing?
    ___________________________________
    Previously: 03 A4 1.9TDI , 05 A4 2.0TDI S-Line, 05 A6 2.7TDI S-Line Quattro , 06 A4 2.0TDI S-Line Avant, 08 2.0 TDI MK5 GOLF GT SPORT TDI 170 DSG, 10 A6 2.0 LE MANS 170, 19 G30 520d MSport
    Now: waiting
    May 2007
    Thanks both for your reply i thought it might be the turbo as well but because this is my first audi tdi just wanted to ask the question. If it is the turbo it has only just started to work and seems very noisy. Going to have a dig around the engine on my day off wish me luck.
    May 2007
    got same problem in my passat i think its turbo noise ........does your car sound loud when you lower windows ????
    May 2007
    Right the fan noise has now gone but so has all the cars power so iam thinking that the noise i was hearing was in fact the turbo and everything was fine. But now their is somthing wrong with the car can any boudy help?
    Apr 2007
    Hampshire
    Pop the bonnet with the engine running, rev the engine hard, if you cant hear the turbo spin up then you've got a problem with the turbine blade i'd hazard a guess. May just be jammed, if its disintergrated then you'd of heard bits going through the exhaust! Surprised your not getting an ECU warning light though? If you can hear the turbo in the above test give it a high speed motorway run (as in 70mph of course!) to blow out any cobwebs. If you cant hear the turbo, get it to the garage! I get the wind noise on my V6 and the recirculation button works by the way!
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
    May 2007
    Thganks for the reply. the problem was getting worse so i disconnected the MAF sensor and removed the air filter gave it all a dam good clean and touch wood the care is driving better than ever. But will take it for a high speed run at 70mph over the week end and see how we get on (Fingers crossed)
    May 2007
    sorry to sound like a total thicko but what is the MAF sensor ?? and where is it located
    Canada
    Quote Originally Posted by hendy View Post
    Mass air flow or MAF, it senses the air going into the turbo so the ecu can control the amount of boost. Its located after the air filter and has a connctor in it.
    See below
    Last edited by onzarob; 13-05-2007 at 08:53 PM. Reason: Sorry typing was terrible!
  1. MK4 Golf 2.0 GTI - Strange noise when accelerating
    By yeahdisk in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2007, 09:01 AM
  2. Bora hesitation when accelerating
    By scubaking in forum Bora - 1998 - 2005
    Last Post: 29-03-2007, 05:33 PM
  3. Golf Mk3 Gti 8v Problems Accelerating
    By Mowgs in forum Golf MK3 - 1993 - 1999
    Last Post: 17-02-2007, 07:37 PM
  4. Unusual Vibration When Accelerating
    By Robbie~F in forum Audi A3 - Archive Topics
    Last Post: 22-11-2006, 12:40 PM
  5. Exhaust smoke (black) when accelerating
    By FAB in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-01-2006, 12:14 AM
