Thread: Golf Mk3 Cabrio wont start!!
Results 1 to 10 of 10
  1. Golf Mk3 Cabrio wont start!!
    Oct 2006
    drebyshire
    Hi, Recently had my Golf go into a garage for some MOT work to be done. when got it back the car wouldnt start... ang the garage that did the repairs and they said they couldnt get it started since had it from MOT station....and had been starting it by bypasing the emmobilliser ( with a wire somewhere under the bonnet ).
    When i turn on the ignition all the lights light up and get a " IN 02" message come up on dash display...Can anyone help plz, been without car for a couple of weeks now.
    Vassy
    May 2007
    Raunds
    If you drove in there fine and it was all working then maybe the garage messed up something on the car....u could rip your immobiliser out but cudnt say what o2 sign means....could be the 02 sensor, (lambda)
    Ash
    Oct 2006
    drebyshire
    Just done an electrical diagnostic test and found it to be the ignition switch that is faulty. car starts is i unplug the lead from back of ignition and put a probe in the plug with power running through it.
    neileg Guest
    IN-02 is telling you that it's due a 20k service.
    Oct 2006
    drebyshire
    thanks bud, got the starting problem sorted and will book it in for a service
  6. a new problem now
    Oct 2006
    drebyshire
    Got the car starting ok now with a new ignition...but now the clock resets too 00.00 and the trip milage resets every time turn the car is turned off. Anyone help?
  7. Re: a new problem now
    Dec 2007
    Quote Originally Posted by Vassy View Post
    My Mk3 TDi has just started doing this exact same thing.... did you ever get to the bottom of what caused it?
    Cheers,
    stoo
  8. Re: Golf Mk3 Cabrio wont start!!
    Oct 2006
    drebyshire
    Cheers,
    stoo
    No i didn't m8, had it booked in to be sorted but wrote it off a couple of weeks b4...My baby now in VW heaven
  9. Re: Golf Mk3 Cabrio wont start!!
    Dec 2007
    Bummer.
  10. Re: a new problem now
    neileg Guest
    Sounds like your battery voltage is dropping right down. Could be as simple as topping up your battery with de-ionised water.
    Been there, done that!
  1. Replies: 2
    Last Post: 10-01-2008, 02:18 PM
  2. 1998 GOLF GL wont START.. PLS HELP
    By slykest in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-04-2007, 12:14 AM
  3. 1998 tdi golf wont start
    By a1alan in forum New Member Introductions
    Last Post: 11-04-2007, 10:57 PM
  4. a6 1.8t wont start
    By loco in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-01-2007, 10:22 PM
  5. a6 1.8T wont start
    Last Post: 06-01-2007, 12:21 AM
