Thread: passat engine rpm
  1. passat engine rpm
    May 2009
    fin
    What should be Passat v6 2,8 l engine real rpm ? Now itīs 640rpm
  2. Re: passat engine rpm
    Aug 2008
    Here are the idle speeds for emission checks on the 2.8litre (AMX) engine which is what my 2003 model has. I should think the idle speeds for different versions will all be similar if not the same:
    Engine temperature min. 80 ąC
    Idling speed
    Vehicles
    with four wheel drive 620 . . . 740 rpm
    without four wheel drive 710 . . . 860 rpm
    Increased idling speed 2500 . . . 3000 rpm
    Lambda probe version step-type probe
    Voltage excrusion min 0,300 Volt
    CO content at increased idling max. 0,3 Vol. %
    Lambda at incrased idling speed 0,97 . . . 1,03
    Catalyst warm-up time 2 Minute(s)
    Test speed Idling speed
    Idle speed and ignition timing are non adjustable.
    A digital readout of the idle rpm can be obtained with a vag-com interface.
  1. oil warning signal
    By ger83 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 07:20 PM
  2. Is G12 the only engine coolant of choice for a Passat
    By turbonutter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2009, 06:47 PM
  3. Please Help Battery + Climate Control Unit + Engine + What's next?
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2009, 07:39 PM
  4. How does the Quattro system work?
