Thread: Alarm LED
Results 1 to 10 of 25
  1. Alarm LED
    Apr 2009
    Does anyone else have issues getting the alarm LED (the one on the top panel of the driver's door) to flash?
    Most of the time when I lock the car, the LED doesn't activate. I've noticed that if I then unlock the car, and re-lock it, the LED gives six rapid flashes and then flashes normally.
    The manual states that just locking the car will activate the alarm, although it makes no reference to the LED. The only reference I can see to the LED is in the section on dead-locking, where if you puch the lock button twice the dead-locking is deativated, but I'm not doing this.
    Does anyone have any ideas?
    Thanks.
    VW Golf Mk.6 1.4TSi (122PS) SE Georgia Blue Metallic, 2-zone climate control, Auto hold, front fogs, Sat Nav, Dynaudio, Flat tyre indicator, Luxury pack, Multi-function leather wheel, Parking sensors, Park Assist, Rear view camera, Winter pack.
  2. Re: Alarm LED
    Aug 2009
    london
    I dont think there is anything wrong with your car. It's just the way it is.
  3. Re: Alarm LED
    South London. UK
    Quote Originally Posted by jjh View Post
    Of course it should flash.
    After locking my car with one click of the blipper, my LED light in the door flashes about every 2 to 3 seconds. As far as I'm concerned, if activated, your car's LED should flash to confirm activation and that the car's alarm is armed and active.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  4. Re: Alarm LED
    Jul 2009
    Hertfordshire, UK
    As far as I know, mine has been fine.
    Golf VI GT TSI 1.4 160PS, 18" Vancouver alloys, air conditioning '2Zone', luxury pack, winter pack, RCD 510 with Dynaudio, parking sensors
  5. Re: Alarm LED
    Aug 2009
    West Yorkshire, Haworth
    Quote Originally Posted by Blackthorn View Post
    Thanks.
    Once you lock the car the Red LED light should flash every 2 - 3seconds, if it does not then try unlocking and locking again ? if it still does not flash then you may have a problem. worth checking to make sure the interior alarm is on behind the drivers seat
  6. Re: Alarm LED
    South London. UK
    Quote Originally Posted by moe360 View Post
    What should be 'on behind the driver's seat'?
  7. Re: Alarm LED
    Aug 2009
    Quote Originally Posted by HHGTTG View Post
    I mean the little switch located just to the right behind the drivers seat which turns the motion sensor alarm off it's a little switch it's also demonstrated in the manual
  8. Re: Alarm LED
    South London. UK
    If that switch was inadvertantly set, it only operates the once. Once you unlock the car, the default setting i.e normal operation in restored. This interior motion sensor de-activation switch needs to be set each time you require it. i.e leaving someone or an animal inside or leaving a window, sunroof ajar or when towing the car.
    2 0 0
  9. Re: Alarm LED
    Feb 2007
    A number of rapis flashes is normally a fault finding diagnostic, the number of flashes indicating the fault.
  10. Re: Alarm LED
    Aug 2009
    It was just a suggestion to check in case it was off I usual leave it on all the time
  1. Question Alarm Indicator LED stays on for 30 seconds before blinking
    By BlackSmoke in forum Golf MK5 - 2004 - 2009
    Last Post: 17-04-2010, 11:56 AM
  2. Please Help Alarm LED
    By Brian566 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-11-2009, 06:49 PM
  3. Please Help Alarm failure on passat 2001 2ltr
    By ST.Alban in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 08:18 PM
  4. Please Help Factory Alarm stopped working
    By avata_jo in forum Golf MK2 - 1984 - 1992
    Last Post: 21-07-2009, 07:01 AM
  5. A6 Alarm LED
    By Tazdevil1977 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-11-2007, 02:12 PM
