Thread: Pertronix Ignitor II, for use with Bosch 009 or 050 distributors.
  1. Pertronix Ignitor II, for use with Bosch 009 or 050 distributors.
    Oct 2007
    Hi
    I recently purchased an unused Pertronix Ignitor II, for use with Bosch 009 or 050 distributors.
    Unfortunately it came without instructions, can anyone help?
    thanks
    esky
  2. Re: Pertronix Ignitor II, for use with Bosch 009 or 050 distributors.
    Apr 2010
    cumbria
    the little black bush pushes over the distributor center [it is a very tight fit]
    the bit with the wires replaces the points.
    you then feed the two wires through the side of the distributor and remove the condensor
    the red wire must go on the + [15 ] terminal the black wire to the _ [1] terminal on the coil
    do not conect the wrong way around it will blow the unit !!!
    set the gap using the slip of plastic that is in the kit and check the timing.
    dead easy realy
  1. Heated windscreen problem
    By Nautilus in forum Touran - Sharan - Caravelle
    Last Post: 31-12-2008, 10:27 AM
  2. Stereo don't work, but think its the wiring
    By macca73 in forum Touran - Sharan - Caravelle
    Last Post: 19-04-2008, 09:30 AM
  3. Mystery Fuse
    By richard@thebrae in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2008, 10:00 PM
