Thread: Car starts and cuts out
Results 1 to 10 of 11
  1. Car starts and cuts out
    Dec 2008
    Ok took the clocks out of my car and disconnected the battery b4 i started. put every thing back reconnected the battery and started the car. It started and then cut out. The imobiliser key icon is flashing on the car and the water jet icon is on as well along with a beep. HELP
  2. Re: Car starts and cuts out
    134 Post(s)
    2022 Post(s)
    It’s rare but it does happen, the clocks will need re-matching to the engine ECU which requires a registered version of VAG/COM or similar. If it is post 2003, it may have to go to VW. Try leaving the ignition on for an hour.
  3. Re: Car starts and cuts out
    Dec 2008
    Its a 1998 tdi. Is it easy to do with vagcom? have the cable but a unregistered copy. I do know some1 who has a registered copy.
  4. Re: Car starts and cuts out
    134 Post(s)
    2022 Post(s)
    If you go into Instruments 17, Adaptation 10, Group 00, read and save, then exit and turn off the ignition for 30 seconds, it may re-adapt but only using a registered version of VAG COM. Otherwise you will have to get the four digit pin code out of the instruments and VAG-COM cannot do this.
  5. Re: Car starts and cuts out
    Mansfield, UK
    I can help you with PIN/SKC codes.
  6. Re: Car starts and cuts out
    Dec 2008
    Quote Originally Posted by shark_90 View Post
    The only problem is that im not in England so cant come to you with the car . Or can this be done with out having to go to you. Have been told by some else to disconnect the battery and then connect the terminals (not battery) together 4 20 secs and then start the car as normal. Have u heard of this?
  7. Re: Car starts and cuts out
    Mansfield, UK
    Ah, I see. I have heard that mentioned but can't say that it works.. Worth a try I guess.
  8. Re: Car starts and cuts out
    Dec 2008
    Ok i have done a fault read with vagcom and here are the main points.
    3 faults
    01128- immobilizer pickup coil (D2)
    35-10---- intermittent
    01176-key
    07-00-signal too low
    00779-Outside Air temp sensor (G17)
    30-00 open or short to B+
    Along with another 4 things but thats all central locking and interior lights. which i have just learned to live with.
  9. Re: Car starts and cuts out
    Quote Originally Posted by 808 View Post
    3 faults
    01176-key
    The first 2 are causing your problem, when you removed the instruments you may have broken a wire between the cluster and transceiver coil or not put a plug back in correctly, or damaged the socket. The coil emits pulses that the transponder in the key responds to, if the coil is intermittent that would explain the low key signal. Take the shells off the steering column and check.
  10. Re: Car starts and cuts out
    Dec 2008
    Cheers m8 found a wire i had traped, woops. Sorted it out and the cars up and running again . Thxs for all the replys every body was very helpful
  1. Please Help Car stops at random, but in the morning it always stars
    By Killian Lobato in forum Golf MK3 - 1993 - 1999
    Last Post: 03-06-2009, 05:35 PM
  2. A6 cuts out after 10 minuutes ?
    By ashneilo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-04-2009, 09:40 PM
  3. Starting problems and car cutting out
    By HELPME in forum Audi A3 - Archive Topics
    Last Post: 18-02-2008, 02:35 PM
  4. 2.0TDI Sport - Starts then cuts out after 500 yards
    By ibarker in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2008, 02:05 PM
  5. Golf 1.6 Mk4 - engine cutting out while driving...
    By hemang02 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-10-2007, 12:59 PM
