Thread: Fault Found: 01170 - Fuel Injection Duration Sensor (G175) 03-00 - No Signal
  1. Exclamation Fault Found: 01170 - Fuel Injection Duration Sensor (G175) 03-00 - No Signal
    Glasgow, Scotland, UK
    Help,
    Having problems diagnosing a running problem with my 'N' reg Golf Turbo Diesel.
    Seems to judder when cruising - first noticed travelling at 50mph after slowing down to go through road works, as soon as I accelerate or put the clutch down the judder stops.
    I plugged in my laptop and an OBD reader, which I had from a previous car and installed vag-com, and managed to get into the engine control module test and read the fault codes and got the following read out:
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 028 906 124 A
    Component and/or Version: Turbo-Diesel V01
    Software Coding: 00127
    Work Shop Code: WSC 00000
    1 Fault Found:
    03-00 - No Signal
    Have searched high and low for what this means, but can not find out, contacted my local dealer and they said the fault code will not help and I need to book it in for a check.
    As noted the car is quite old, has done 170,000 miles, but I am not wanting to spend a fortune at the dealers.
    Can anyone help?
    Thanks in advance.
  2. Re: Fault Found: 01170 - Fuel Injection Duration Sensor (G175) 03-00 - No Signal
    Southern County Softy
    20 Post(s)
    What about clearing the fault and seeing if it returns...
    A4 2.5 tdi QS (mapped)
  3. Re: Fault Found: 01170 - Fuel Injection Duration Sensor (G175) 03-00 - No Signal
    Will try that today . . . and let you know,
  1. Replies: 2
    Last Post: 24-11-2010, 11:35 PM
  2. Vw bora lack of power 1.9 tdi pd
    By saabsalltheway! in forum VCDS - Help Requests
    Last Post: 03-06-2009, 08:59 PM
  3. adapting comfort indicators on Polo 9N
    By djl78 in forum VCDS - General Questions
    Last Post: 13-05-2008, 09:51 PM
  4. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
