Thread: tips on changing scuttle panel #9think its called that)
  1. tips on changing scuttle panel #9think its called that)
    south wales
    well after my past problems ive decided not to take my car back to the garage that buggered it up when they serviced it.
    so im going to have a go at repairing the broken scuttle panel.
    ordered the new part so should have it by the weekend.
    any tip on changing it? i know crasher said they are very brittle and can brake easily.
    im guessing its a straight forward job but can see what holds it in place around the pollum filter area?
    hopfully this will cure my water leek.
  2. Re: tips on changing scuttle panel #9think its called that)
    Oct 2009
    Worthing
    How much is a new one as I'm missing mine.
    JAmes.
  3. Re: tips on changing scuttle panel #9think its called that)
    Feb 2009
    Won't cure the leak around the pollen filter. You need to remove it and replace the gasket under the filter housing.
  4. Re: tips on changing scuttle panel #9think its called that)
    south wales
    new panel was £14 mines cracked and the polum filter was/is also dripping wet.
    ive also bought the puty from vw so i,l do that while im at it.
  5. Re: tips on changing scuttle panel #9think its called that)
    south wales
    changed the scuttle panel today quite a easy straight forward job the hardest part was getting one of the wipers off.
    not bothered with resealing the rest of the box yet as it was getting dark,
    when i removed the filter its was dripping wet again there was also water underneath it.
    time will tell if its worked going by the weather i,l know soon enough
  6. Re: tips on changing scuttle panel #9think its called that)
    Aug 2008
    When refitting, don't press the scuttle in too hard on the bottom of the windscreen. Maybe I was unlucky because it was the day after when it cracked and I had to have a replacement screen.
    I got the wipers off easily using a hammer and suitably sized combination spanner as a wedge. Hard to describe but it worked well with no damage to anything.
  1. Audi A4 Dashboard Instrument Panel Light Bulb Dash Light Fix
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2011, 08:39 AM
  2. Tips On Seat Changing
    By joecrow in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 29-11-2007, 05:13 PM
