Thread: help a4 estate 1.9 tdi 130 starts then dies
  1. help a4 estate 1.9 tdi 130 starts then dies
    halifax england
    hi need sum help if any 1 can , the car starts then cuts out as tho it is being starved of fuel i have checked the air filter thats fine fuel pump sounds to be buzzin i suspect it may be down to the injecters has any body had a prblem like this please help thanks chris
  2. Re: help a4 estate 1.9 tdi 130 starts then dies
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Do you have any amber warning lamp flashing on the instrument cluster? This could be the Immobiliser.Same symptoms as you describe.If not,does the engine fire straight off key,or does it crank for a while before firing?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: help a4 estate 1.9 tdi 130 starts then dies
    Mansfield, UK
    Yes take a look out for the yellow car with a key icon, sounds exactly like immobiliser symptoms.
  4. Re: help a4 estate 1.9 tdi 130 starts then dies
    halifax england
    thanks but imobiliser has cheacked nothing to do with that i had it running 2day it runs fine but only at high revs and smokes alot then whe it is let to idle it will be ok for ten secounds or so then sounds like its run out of juice and dies ive had it on the scanner and it is showing no fault codes thanks again for your help please any more advice chris
  5. Re: help a4 estate 1.9 tdi 130 starts then dies
    Mansfield, UK
    Have you checked all your vacuum pipes for leaks?
  6. Re: help a4 estate 1.9 tdi 130 starts then dies
    Nov 2008
    20 Post(s)
    As a check,test the Needle Lift Sensor Injector(wire attatched to it), around 110 Ohms is ok.
    Alan.
  1. 2.5 (180) vs 1.9 (130) TDI
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-12-2007, 04:12 AM
  2. New Škoda Fabia Estate Uk Pricing And Spec Is Announced
    Last Post: 03-12-2007, 08:08 PM
  3. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  4. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
