Thread: rear springs?
  1. rear springs?
    Feb 2009
    hi, can anyone tell me how to remove and replace the rear springs on a 1999 gt tdi. any special tools needed?
  2. Re: rear springs?
    Near Blackpool
    48 Post(s)
    When i changed mine i did something like this:
    • Jack up car and remove rear wheels
      • undo bolt from bottom of the shocks (i did one at a time IE took one shock bolt out change spring then put the bolt back then repeat)
      • Then i stud on the rear axle (i weigh quite a bit) and bounced slightly to fully extend the spring. Then managed to pull the spring out.
      • Then i took off the top mount (Just sits on top of the spring and is held in by the force of the spring)
      • I then got spring sat on bottom cup and proceeded to stand on the axle again. Haynes manual describes using wood and a lever. I used body weight! Levered the axle down and slipping the spring and top mount into the slot that holds it all in place. I then put the shock bolt back and went and did other side!
    This may be a little unorthodox but that is how i did it. I did it on a 90bhp tdi. But i am guessing there wont be much difference. Just don't level the axle too much and it could damage the axle bushes!. Good luck!
  1. T4 Transporter chewing rear springs
    By MAZI in forum The Commercial Range
    Last Post: 13-09-2009, 09:22 PM
  2. Question T4 Transporter chewing up rear springs
    Last Post: 08-09-2009, 01:26 PM
  3. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  4. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  5. How does the Quattro system work?
    By webchem in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 01-07-2007, 04:44 PM
