Thread: VW Passat 2.0 Tdi BKP BIG PROBLEM!
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
  1. VW Passat 2.0 Tdi BKP BIG PROBLEM!
    Apr 2009
    sheffield
    Hi all, i have a passat on a 2005 2.0 Tdi 140 bhp engine code BKP.
    I was driving the car and the oil pressure light came up. maybe a minute or two after i hear 2 loud whooosh noises from under the bonnet.
    I pull over and have the car recovered to a local garage.
    Ive now changed the oil pump which was the problem. the garage are telling me now the turbo has gone. however theres a tapping noise coming from the engine.
    should i change the engine with turbo or just turbo?
    Any advice would be greatly appreciated.
  2. Re: VW Passat 2.0 Tdi BKP BIG PROBLEM!
    Jul 2007
    Sister car to mine did just the same as yours, no oil pressure then knocking = new engine.
    Mine just didn`t bother with the knocking.............. (new engine!)
    If its run without oil pressure I would expect the bottom end to be kaput. Sorry, but it`s been well documented on here.
  3. Re: VW Passat 2.0 Tdi BKP BIG PROBLEM!
    Apr 2009
    sheffield
    Thanks for the reply angus.
    Do you know if vw are fixing this FOC?
    thanks again
  4. Re: VW Passat 2.0 Tdi BKP BIG PROBLEM!
    Jul 2007
    Mine went at 28k, the other went at 18k, both fixed without quibble by vw.
    There was a known fault on the oil pump drive (poor case-hardening on an idler gear) which leads to catastrophic failure on units built late 2005/early2006 (think Crasher has posted engine or chassis numbers somewhere), which affect VWs, Audis, Skodas and Seats using the 140TDI lump. It has been well publicised but VW chose not to do a recall, so even if its out of warranty morally they should fix it.
    Do a bit more research, get the facts together and prepare to battle. Best of luck.
  5. Re: VW Passat 2.0 Tdi BKP BIG PROBLEM!
    1840 Post(s)
    Oil pump drive spindle failure, very very common on cars up to around the middle of 2006 production.
  6. Re: VW Passat 2.0 Tdi BKP BIG PROBLEM!
    Apr 2007
    France
    12 Post(s)
    "If only everything in life was as reliable as a Volkswagen".....
    1996 Laguna 2.2D
    1977 MGB roadster
  7. Re: VW Passat 2.0 Tdi BKP BIG PROBLEM!
    Mar 2008
    Old Wessex
    I hear about this far too often!
    Very worrying considering I own the same car, same MY, same engine....
    What is your mileage?
    It wouldn't be quite so bad if the preventative measure (retrofit of revised oil pump) wasn't so damn expensive either!
    Keep us posted. All the best!
    - VW Golf 1.9 GT TDI (130) - 2003
    - VW T5 Camper - 2.5 TDI - 2008
    - VW Passat Estate - 2.0 TDI - 2010
  8. Re: VW Passat 2.0 Tdi BKP BIG PROBLEM!
    Apr 2009
    sheffield
    hi again, called VW in and am now waiting for a response back from them.
    But to be honest dont think ill get much joy as she said there had been no product recall on the car as regards to the oil pump. also they were unaware of this being a common fault
    P.s the milage is now just over a 100,000 which should be nothing lol.. i remember a saying.... " you'll get the full potential of of your engine on a vw at 100,000 as everything has jus worn in"... YEH RIGHT!
  9. Re: VW Passat 2.0 Tdi BKP BIG PROBLEM!
    Apr 2007
    France
    12 Post(s)
    'Unaware'? - That completely disagrees with what Crasher says (and he should know).
    It's a known fault, and VW saying they've not done a recall doesn't mean a thing.
    As Angus says, do some searching around on here - his experience is a start - arm yourself with the facts and have another go.
    1996 Laguna 2.2D
    1977 MGB roadster
  10. Re: VW Passat 2.0 Tdi BKP BIG PROBLEM!
    Mar 2008
    Old Wessex
    ^^^ What Quatrelle said.
    Good luck!
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  3. VW GOLF GT TDi - Problem!!
    By Ranger Bob in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2007, 09:49 PM
  4. Vw Passat 4motion Estate Voted Towcar Of The Year 2007
    By Ben in forum Chat - Anything with wheels
    Last Post: 26-08-2007, 07:35 AM
  5. VW Passat 130 TDi turbo problem
    By Timbo in forum Archive posts
    Last Post: 01-12-2006, 03:46 PM
