Thread: Auto window re-adjust on door opening
Results 1 to 10 of 13
Hybrid View
  1. Auto window re-adjust on door opening
    Aug 2009
    folkestone
    I have a Audi TT quattro coupe (180) 2001. The driver's side window does not drop when you open the door. The near side door works ok. Any ideas?
  2. Re: Auto window re-adjust on door opening
    Southern County Softy
    20 Post(s)
    Does the DIS show the door open, does the lights on buzzer work ?
    A4 2.5 tdi QS (mapped)
  3. Re: Auto window re-adjust on door opening
    Aug 2009
    folkestone
    Quote Originally Posted by kite View Post
    The boss is away at the moment (its her car I have an A6 Advant). I will check when she gets back. Thanks!
  4. Question Re: Auto window re-adjust on door opening
    Aug 2009
    folkestone
    No it doesn't please advise
  5. Re: Auto window re-adjust on door opening
    20 Post(s)
    Odds are it the microswitch built into the door lock.
    I'm sure there's a "how to" on the TT forum.....
    I'll go look and post a link
  6. Re: Auto window re-adjust on door opening
    20 Post(s)
    A bit of light reading......
    http://www.tt-forum.co.uk/forum/viewtopic.php?t=56261
    Or buy a new lock.....
  7. Re: Auto window re-adjust on door opening
    Jul 2007
    Chester
    Try the window reset:
    Turn the ignition on - don't start the engine
    windows down and then straight back up
    when the windows are up release the switch momentarily
    pull the switches back up and hold for 3 to 5 seconds
    let the switches go
    ignition off
    If this won't help, you probably have broken microswitch in door lock mechanism. Solution is to buy a new mechanism from Audi, it cost £102.
    Dan
  1. If you were buying your B7 3.0TDI again which box would you choose?
    By Marc1 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-03-2010, 03:13 PM
  2. Auto Window not working.
    By JezzaL in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-11-2009, 03:24 PM
  3. Polo 6N2 electric window fault
    By zoro in forum Polo - Derby - Lupo - Fox
    Last Post: 18-11-2008, 10:11 AM
  4. Audi Ancestor Could Be Most Expensive Auctioned Car Ever
    Last Post: 04-02-2007, 07:12 PM
