Thread: Indicators & temperature gauge not working correctly
Results 1 to 9 of 9
  1. Indicators & temperature gauge not working correctly
    We had a massive downpour while I was driving in the rain and now my indicators are not working correctly. I indicate and sometimes they flash for a few seconds and go off and sometimes they only flash once and go off?
    Could it be water in the relay or something?
    The other problem I have been having for a while is the temperature gauge sometimes does not work properly. For example this morning I was driving for about 30 mins and the gauge only showed 70C instead of 90C?
    Any suggestions will be appreciated.
  2. Re: Indicators & temperature gauge not working correctly
    Southern County Softy
    20 Post(s)
    Faulty coolant temp. sensor or a dodgy themostat.
    Indicator relays are known to fail.
    A4 2.5 tdi QS (mapped)
  3. Re: Indicators & temperature gauge not working correctly
    Quote Originally Posted by kite View Post
    Thanks for the info, are these quite easy to change?
  4. Re: Indicators & temperature gauge not working correctly
    20 Post(s)
    Have a search around the forums, i think you'll find the info you need.
  5. Re: Indicators & temperature gauge not working correctly
    Where is the best place to get the indicator relay online?
    I got a quote from the dealers and they want £35.90
    Thanks.
  6. Re: Indicators & temperature gauge not working correctly
    Finally got round to changing the relay and now the indicators work one thing I have noticed since doing this is when I lock the car usually all the indicator lights flash but they do not do that anymore? They still flash when I unlock the doors.
  7. Re: Indicators & temperature gauge not working correctly
    20 Post(s)
    Not flashing when locking is a sign the alarm is not set for some reason.
    Check all doors, bonnet and boot are shut
  8. Re: Indicators & temperature gauge not working correctly
    I know I thought it was a door or the boot not being shut properly but everything is shut and the red LEDs flash on the doors otherwise they would not be flashing if something was not shut.
    Very strange?
  9. Re: Indicators & temperature gauge not working correctly
    20 Post(s)
    Time for a fault scan....
  1. Temperature gauge reading lower than actual temperature
    By garymansell in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2009, 04:29 PM
  2. Temperature Gauge
    By Brian Rouse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2008, 05:54 PM
  3. Numerous Details on Digital Air Con Display
    By sooty in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 08:09 AM
  4. 1998 Audi A4 Temperature Gauge
    By EmmettC in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 11:19 AM
  5. Temperature gauge not working
    By KirbTheSwerve in forum Golf MK2 - 1984 - 1992
    Last Post: 19-01-2007, 07:35 PM
