Thread: A4 intermittent electrical fault
  1. A4 intermittent electrical fault
    Mar 2008
    Audi A4 S-reg 1.9tdi...
    Can someone explain why my windscreen wipers stop working? The indicators also stop working although hazard lights remain active. I have noticed that when this happens, the following items also fail, Fog lights, rear window heater, indicators windscreen wipers and the air con/heater. Its an intermittent fault and its not clear which item is to blame. I suspect the heater and logic controls for it, but is there anyway all these functions could be linked in some way?
    The main dealer has replaced the ignition switch...it did not cure the fault.
    Any ideas welcome, thanks
  2. Re: A4 intermittent electrical fault
    Oct 2009
    Redcar
    vag com might bring a code up? could be a bad earth somewhere? if its intermittent, i cant see if being a fuse. but its worth a look.
  3. Re: A4 intermittent electrical fault
    Mar 2008
    Thanks cusford, its not a a fuse, I know that, but I guess it could be a bad earth...where would I look for this?
  4. Re: A4 intermittent electrical fault
    Oct 2009
    Redcar
    i wouldn't know i'm afraid. maybe someone local has vagcom? that will help a lot as it will come up with codes ending in 'short to ground' ..
  5. Re: A4 intermittent electrical fault
    Mar 2008
    Okay thank you for your help
  1. A4 2005/05 2.0 tdi SE - fault help
    By barefootin in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-07-2009, 01:52 PM
  2. Vag Results , Anyone want to quote me and repair?
    By pete2vinal in forum Golf MK4 - 1999 - 2004
    Last Post: 13-02-2008, 04:35 PM
  3. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
