Thread: Winter wheels
  1. Winter wheels
    Geneva, Switzerland
    I am (still) mulling over whether to buy a new Golf 1.6 TDI and have a question about wheels and tyres...
    I have an extra set of wheels and tyres with my current car (2005 Volvo V50) which I use during the winter.
    The tyres, sitting on 16"rims, are the same size as the Golf that I may buy which are 205/55R16. The rims have 5 holes which is the same as the Golf I believe.
    Short of taking one to the garage and asking them is there any way that I can I tell whether or not these wheels will fit on the Golfs hubs?
    Matthew
  2. Re: Winter wheels
    Feb 2007
    There are three key elements to check on the wheels.
    1. The PCD of the bolt holes, ie the size of the circle that runs through the centre of the bolt holes. Volvo v50 use 108mm pcd, golf 6 uses 112mm. You key be a able to get adaptors/bolts to overcome this.
    2. The diameter if the hole in the centre of the wheel that locates over the wheel hub/ bearing cap - v50 are 63.1mm, don't know the golf sorry
    3. The offset or ET of the wheels - this will be stamped on the back of the wheels somewhere. V50 range from 38-45mm, golf6 Factory wheels are more like et50 but I've seen aftermarket wheels quoted at et42-45mm so you may be fine on offset.
    A bit of Internet searching should reveal all
  1. Wheels
    By Mr Tibbs in forum Wheels and Tyres
    Last Post: 28-06-2009, 12:12 AM
  2. Replacement Wheels / Tyres for the Winter?
    By WeegieBob in forum Golf MK6 - 2009 - 2013
    Last Post: 02-06-2009, 08:38 PM
  3. Wheels for A6 TDI for winter tyres?
    By alexjcrossland in forum Archive posts
    Last Post: 11-11-2007, 09:51 AM
  4. How does the Quattro system work?
  5. Insurance & Modifications ££££££
    By torrox in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-05-2007, 07:39 PM
