Thread: Clutch issues
Results 1 to 10 of 11
  1. Clutch issues
    Jul 2009
    uk
    In tesco's car park yesterday when the clutch pedal stayed on the floor!!
    Only way i could get it up was to pull it by hand (No pun intended!) But there was nothinbg there. I looked in the brake master cylinder and it looked a bit low so i topped it up......it took nearly 1/2 a litre of fluid!!
    I checked all the pipes that i could see to look for leaks but could not see any. Tried the clutch again, but no change.
    I did notice anoise coming from under the battery tray when i pumped the cluth pedal, it sounded like a squwelching noise!!!!
    After looking round on the forum i think it maybe one of 3 things.....
    1. a fluid leak somewhere
    2. Clutch slave cylinder has gone
    3. Brake master cylinder has gone
    Is there any way i could check to find out which cylinder is knackered?
    Brakes are still working ok.......
    Thank you
  2. Re: Clutch issues
    Jul 2009
    uk
    Just tried to trace the leaking fluid with a eazi bleed kit and it is comoing from the seal on the gear box!!!
    I am assuming there is something in there i need to change!!!!!!!
    Please advise
  3. Re: Clutch issues
    Jul 2009
    uk
    Been told that it is the concentric slave cylinder in side the gear box!!!!
    Getting done on tuesday
    Thinking that i might as well get the clutch done at the same time as it is probably covered in brake juice!!
    Anyone know of the best place to get one from?......it is the AJM engine code if that i any help......will i need the gearbox code as well? if so where is it???
    cheers
  4. Re: Clutch issues
    133 Post(s)
    1991 Post(s)
    I only ever fit genuine VAG concentric slave cylinders, even when I fit an LUK or Sachs clutch. The cylinders cost about £35 from VW but they come with a two year parts and labour warranty so should it fail within 2 years, VW will change it for you.
  5. Re: Clutch issues
    Jul 2009
    uk
    Thanks Crasher, i will get one from VW, I am in Notts tomorrow, Bulwell, there is one on the way in if i am correct, coming down the 614 to the TA centre, We may have been in the same line of work looking at your pictures!!
  6. Re: Clutch issues
    133 Post(s)
    1991 Post(s)
    That is Bulwell TPS, very good bunch of people work there.
  7. Re: Clutch issues
    Jul 2009
    uk
    Crossed wires i think, i used to instruct at the TA Centre!!!.........H4H, top charity
  8. Re: Clutch issues
    Jan 2008
    nottinghamshire
    yes get a genuine slave, mine failed after a year and vw had to fix it...
  9. Re: Clutch issues
    133 Post(s)
    1991 Post(s)
    Quote Originally Posted by peteisfishing View Post
    I see where you are coming from. The Avatar is the Bovingtion Tiger 1 (my all time favourite tank) and H4H, well what can I say, I didn’t have the guts to join up and fight so the least I can do is try and give those injured chaps some help.
  10. Re: Clutch issues
    Jul 2009
    uk
    Fair play to you crasher..i am coming to the end of 22 yrs service, time to experience life in civi street me thinks!!
    Got the gearbox off, I require a new flywheel, clutch and CSC
    Flywheel - £201 + VAT LUK
    Clurch - £84 + VAT LUK
    CSC £24 + Vat
    Gutted but the prices seem ok i suppose.........from GSF car spares, and they had them all on the shelf, the CSC is original VAG part
    The center of the flywheel is shot and the cluthch covered in Brake Fluid
  1. Unusual Clutch Issues
    By taveirne in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-07-2009, 05:59 PM
  2. Clutch pedal issues
    By jonsey24 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-05-2009, 09:19 PM
  3. Clutch problem Golf MK4 GTI 2003 (TDI) 150 BHP
    By rio1981 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-03-2008, 12:13 AM
  4. Shafted....really?
    By Martin Burnard in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 09:44 PM
  5. Replies: 2
    Last Post: 11-05-2007, 12:30 PM
