Thread: 1999 A4 Temperature Gauge Reading -49 Please Help
  1. 1999 A4 Temperature Gauge Reading -49 Please Help
    May 2007
    I have a 1999 Audi A4 2.8. The temp gauge is reading -49 or so and the AC won't turn on. Is there a problem with the external temperature sensor? If so, where is it located? Thanks for your help.
    May 2007
    Leeds
    It is probably located at the very front of your car. Which temperature gauge shows -49? Engine temperature, or air temperature?
    ex Audi 1.9 TDI 1997, AHU
    Audi 1.8 Petrol/LPG
    Audi 1.9TDI AFN Quattro
    Jul 2007
    I have the same problem, did you find out where the sensor is?
    Richie C
    May 2007
    Leeds
    I believe it is right in front of the radiator if it is the air temperature sensor for AC.
    Audi 1.8 Petrol/LPG
    Jul 2007
    yes the air temperature sensor
    Jul 2007
    Fife
    I had this, and i found the battery voltage was poor anyway while checking it so replaced the battery with a new one, and suddenly the temp reading was correct. I used to get -52 to +3 (summer) etc etc just random rubbish. Dont know if just disconnecting the battery for 10 minutes would do the same (remember radio code) as its maybe a software glitch and just needs an ecu reset (by removing NEG battery lead for 10 mins)
    Worth a try...
  1. Temp Gauge reading
    By Spaceman in forum Audi A3 - Archive Topics
    Last Post: 07-03-2007, 04:40 PM
  2. A4 Temperature Gauge not reading
    By GT001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2007, 04:11 PM
  3. temperature gauge
    By cat69 in forum Archive posts
    Last Post: 10-11-2006, 10:23 PM
  4. Bora TDI Fuel gauge reading full
    By cubby in forum Bora - 1998 - 2005
    Last Post: 07-06-2006, 10:17 AM
  5. Bora Fuel gauge reading full on empty tank
    Last Post: 06-06-2006, 06:15 PM
