Thread: common fault on 18t petrol engines
  1. common fault on 18t petrol engines
    Nov 2009
    cleveland
    was drivin on the motorway and just had my oil pressure warning light cum on so pulled over and phoned th AA .when the patrol man came he checked the oil level..was ok i d done it before i set off and informed me there was a common fault on the 18 t petrol engines where the oil stump strainer or pipe get s blocked.and can result in completely knackering ur engine ( my technical term not his)....just lettin u good peeps kno and was wonderin if it s a common fault why isnt audi doin or done something about it...recall for instance?????
  2. Re: common fault on 18t petrol engines
    Southern County Softy
    20 Post(s)
    Yes a common problem with the 1.8T's that have been on "long life" servicing.....
    A4 2.5 tdi QS (mapped)
  3. Re: common fault on 18t petrol engines
    Nov 2009
    cleveland
    hmmm well i ve been servicin my car yearly averaging12500 miles for the past 7 years and have been using castrol edge fully synthentic 5w/30 oil..but have recently topped up with a cheaper oil when stuck on the motorway and oil level light came on so may be thats caused it
  4. Re: common fault on 18t petrol engines
    20 Post(s)
    Have the oil pressure checked, to see if the pump is working properly.
    Remove the sump to clean and check for a blocked strainer.
  5. Re: common fault on 18t petrol engines
    Nov 2009
    cleveland
    thanks for the speedy reply and helpful advice ,much appreciated
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. gearbox isolator switch??????
    By a25c in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2009, 11:29 PM
  3. T4 petrol engines and LPG conversions.
    By hurtgen44 in forum The Commercial Range
    Last Post: 18-10-2007, 09:28 PM
  4. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
  5. Audi Injects Even More FSI Efficiency Into 2007 Range
    Last Post: 04-12-2006, 08:06 PM
