Thread: Indicator stem fault
  1. Indicator stem fault
    Hi Folks. I have a strange problem with my indicators and I could really do with your collective help. The indicator relay in my 2001 130 TDI SE Estate keeps on doing the clicketty-clicks well after the indicator has been cancelled, although it does not actually flash the indicators. I replaced the relay first of all, but that did not solve the problem. It drives me mad and I am just about ready to have the stem replaced. That will be expensive though, as it means taking the steering wheel/etc off. Big bag of Toffee's toanybody that can help.....Please.
  2. Re: Indicator stem fault
    Norfolk
    Do you mean you replaced the hazard relay which is also the indicator relay ? If that didn't work you may well have an indicator switch fault.
  3. Re: Indicator stem fault
    Jul 2008
    I have a 2002 1.9TDi with the AWX engine code with the same problem. My research through this and other forums would suggest that the fault is the indicator switch on the steering wheel column. The steering wheel must be removed to change this and I have been having trouble getting the airbag off so I've just booked it into a local mechanic to do the work on Wednesday. I bought the new switch off ebay for £22 delivered whereas the local VW dealer was looking £45. Here is a link to the ebay seller...http://cgi.ebay.co.uk/ws/eBayISAPI.d...fvi%3D1&_rdc=1
  4. Re: Indicator stem fault
    Jul 2008
    I had the new indicator switch fitted this morning for £25 and no more random clicking hooray.
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  3. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  4. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  5. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
