Thread: Headlamp Connector
  1. Headlamp Connector
    May 2007
    Nottinghamshire UK
    Hi Guys
    I have an intermittent issue with the Drivers side Headlamp. Please note that the headlamp i have are after market ones. That said, i do not believe it to be a problem with the headlamp.
    Sometime when i have my normal beam on, the drivers side does not turn on, but my fog lamp comes on at a fraction of power so i get a low yello glow. There have been occasions where the main beam has just come on.
    Previously I do recall the connector which the headlamp plugs into being corroded and i would be surprised if this is whats happened.
    My question is, where can i obtain the headlamp connector which comes from the engine (female one)? The connector on the headlamp is fine. Would a scrappy be my best shot?
    karachi kops
    audi a4 1.9 tdi se
  2. Re: Headlamp Connector
    Apr 2009
    Cardiff
    I am no electrical expert, but this sounds like a grounding problem relating to that headlamp cluster. The headlamp is being grounded via the fog lamp and hence you have two filaments in the same circuit, the lower resistance fog taking the lion's share of the current.
  1. "How To" change a Polo headlamp bulb
    By KeithS in forum Volkswagen
    Last Post: 03-01-2016, 09:18 PM
  2. Booked in for retrofit mods
    By eob in forum Passat CC
    Last Post: 29-01-2010, 02:23 PM
  3. How To Retrofit Installation of AMI in 2003 A8 (D3/4E)
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 03-09-2009, 06:12 PM
  4. HID Conversions (continued)
    By Col in forum Archive posts
    Last Post: 22-12-2007, 07:56 AM
  5. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
