Thread: VW gear knob removal? change gaitier
  1. VW gear knob removal? change gaitier
    Feb 2006
    i want to change the gaitier in my VW passat '98... i think the gear knob set up is the same on all the VW's of this age...
    any idea how i get the knob off? i tried swisting it and it wont budge...
    cheers
    Jan 2006
    Nottingham
    unclip the bottom of the gaiter from the center console. lift the gaiter up and expose the bottom of the gearknob. you will see a metal collar gripping the bottom of the gear knob to the gear stick. break the metal collar and pull the gear knob off.
    Jan 2006
    Pull the gater up and you will see a clip underneath that holds the gater on. The gater and knob are joined together and come of as a unit.
    Nov 2006
    I've just changed the knob on my 2002 Passat TDi but found it very difficult to break the clip. So instead I actually cut off the plastic lip with a stanley knife and pulled the clip down. The knob then came off and I could take the clip off. This proved essential as the universal gear knob I was fitting had no means of attaching the gaiter. I cut a section off the bottom of the old oem knob and inserted it into the new knob. Then I could reattach the old gaiter without having to buy any new parts.
  1. Gear knob removal
    By CABBIE in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-05-2007, 01:57 PM
  2. A3 removal of Gear stick 1.8 20vT 97 p
    By chocoboy in forum Audi A3 - Archive Topics
    Last Post: 26-02-2007, 01:23 PM
  3. Replacing Gear knob 02 Passat
    By lozza24 in forum Passat - Archive Topics
    Last Post: 28-11-2006, 09:28 AM
  4. changeing the gear knob gaitier
    By Z Man in forum Polo - Derby - Lupo - Fox
    Last Post: 04-02-2006, 02:01 PM
  5. taking off the gear knob
    By Z Man in forum Golf - Jetta - Vento - Bora - Archive Topics
