Thread: slight judder / miss fire
  1. slight judder / miss fire
    this was on my tdi passat before a remap , but now its more prominant , if i hold the throttle and back if off ever so slightly in any gear at any speed, its like the cars being starved of fuel , apply the lightest of touches again and the car is ok , Now could this be the MAF on the way out , or are there any other sensors that can fail . i regulally use millers sport 4 which cleans injectors etc so i rule them out . ANY IDEAS .
  2. Re: slight judder / miss fire
    Sep 2008
    When was the fuel filter changed/checked? I was just told today that a slight judder when using the clutch is probably a failing flywheel!
  3. Re: slight judder / miss fire
    Quote Originally Posted by mouche100 View Post
    thanks , clutch is fine ,car pulls to 80mph in 3rd. sticky turbo veins is the top suspect .
  1. Slight Judder setting off
    By Fatandy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-11-2009, 06:43 PM
  2. Question VW Longlife service and slight judder
    By BORA456 in forum Bora - 1998 - 2005
    Last Post: 31-03-2009, 01:47 PM
  3. miss fire on s4
    By biglad123 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-04-2008, 03:09 PM
  4. Air Con Compressor Query and slight judder at speed
    By Clairehscotland in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2008, 09:49 PM
  5. problem with miss fire on bora
    By vwbora16valve in forum Bora - 1998 - 2005
    Last Post: 29-12-2006, 12:23 AM
