Thread: Lights out on the dashboard?!?
  1. Lights out on the dashboard?!?
    Sep 2009
    Wales
    I've got an Audi A4 1996 and the bulb behind the temperature gauge and fuel gauge seems to have gone because when I switch the lights on these dont illuminate.
    How hard is it to get the clocks out and replace the bulbs.
    I've had a quick look on the outside but cant see any obvious screws...
    Regards
    Dave
  2. Re: Lights out on the dashboard?!?
    Oct 2009
    Lincoln
    If i remember rightly dave.....you need to move the steering wheel down and extend it fully.....then the corrugated panel covering the area below the instrument cluster clips out.......the screws are behind this. I'm sure others on here will be able to give you a more technical description
    The awkward part is getting the clips undone off the rear of the cluster.
    Ive done two in the past, the first was quite easy because the cables were quite long....the second was a pig and had to work by touch.
    It's nothing taxing....just be patient.....if you're near me i'd be willing to help you out if you get stuck ?
  3. Re: Lights out on the dashboard?!?
    Oct 2009
    Redcar
    i can confirm that the above is correct. my bulbs are out, and i've had to move some bulbs around so that i can read my speedo! haha
  4. Re: Lights out on the dashboard?!?
    Sep 2009
    Kenninghall Norfolk UK
    I found it a help removing the bottom panel and the end panel this gives you access to the right hand side of the cluster, as said the fiddly bit is unplugging the cluster by touch. The lamps are available through sponsers on this site the illumination lamps are coloured (orange 10 off) so you can tell them from the function lamps.
    Hope this helps.
  5. Re: Lights out on the dashboard?!?
    Sep 2009
    Wales
    HI,
    So its a bit tricky to change the bulbs then...
    Just to confirm...
    1. Extend the steering wheel and drop it to its lowest place.
    2. Remove the cowling.
    3. Unscrew the screws from underneath the clocks....
    4. Not sure what else to do now...
  6. Re: Lights out on the dashboard?!?
    Sep 2009
    Sorry for the late reply Dave,
    OK you should be able to ease the clocks forward but remember you have all the plugs in the back which you have to unplug on each side of the plug is a little coloured slider you have to move these before the plug will come out.
    Try that and se how you go but be prepared to get frustrated it is the fiddley bit.
    Once you have the clocks you use a socket or long nosed pliers to turn the lamp anticlocwise 1/4 turn it should then come out.
    Remember the colour coding as I now have one lamp in the wrong hole so no illumination apart from the heater plug warning delay.
    Hope this makes sense.
  1. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  2. Problem with Dashboard lights
    By eskimo in forum Golf MK3 - 1993 - 1999
    Last Post: 15-02-2008, 04:12 PM
  3. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  4. 1999 SE Avant - problems with dashboard lights
    By Adam&Eve in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2007, 12:20 AM
  5. A4 dashboard lights not working
    By Pooh_r in forum Archive posts
    Last Post: 04-11-2006, 04:06 PM
