Thread: Golf 1.8 AAM - strange idle
  1. Golf 1.8 AAM - strange idle
    My Mk3 1.8 8v Golf (AAM engine) can't make it's mind up what revs to be at, at idle.
    When starting from cold, it holds around 1000rpm, after warming up it idles at around 900rpm, if you do a quick stop, say fill with petrol, when you re-start it idles at around 1500rpm, then slowly die down to 1000rpm, then after around 5mins will idle at 900rpm again, it's almost like it's going through a warming cycle again.
    It also holds the revs as you change gear, maybe for a second or so before dropping.
    Sealy-VAG codes are:
    Camshaft Position
    (HALL) Sensor (G40)
    Static - No Signal
    00522-158 KWP1281
    Engine Coolant
    Temperature Sensor (G62)
    Sporadic
    00522-155 KWP1281
    Engine Coolant
    Sporadic
    Any clues?
  2. Re: Golf 1.8 AAM - strange idle
    Replace the temp sensor
  1. My first impressions of my GT TDi Golf
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2009, 05:42 PM
  2. Air induction kit for Golf mk3 1.8
    By mav87 in forum Golf MK3 - 1993 - 1999
    Last Post: 06-05-2008, 11:49 PM
  3. problem with ma golf... wont hold idle ??
    By vee-dub-golf in forum Golf MK4 - 1999 - 2004
    Last Post: 20-04-2008, 07:53 PM
  4. Golf Mk3 1994 1.8 Driver spark plug settings
    By sumomus_01 in forum Golf MK3 - 1993 - 1999
    Last Post: 19-02-2008, 02:54 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
