Thread: mk 4 golf
Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 129
  1. Re: mk 4 golf
    #11
    Feb 2009
    crasher,
    could you please offer some advice ... ... id owe you
  2. Re: mk 4 golf
    #12
    Oct 2007
    Unpluging the temp sensor will not help,the issue,i would suggest replacing the sensor,and see if it helps. Otherwise you will need to read the values of the PD units when the engine is hot.
  3. Re: mk 4 golf
    #13
    Feb 2009
    thanks kenny,
    i was told un plugging the sensor would make the ecu think the engine was cold and start it quicker...highlighting a problem with the starter motor??
    as it turns over with force when its hot?
    is there a table of values i can refer to with the VAGCOM unit??
  4. Re: mk 4 golf
    #14
    135 Post(s)
    2037 Post(s)
    An AJM does not have an in tank lift pump and tandem pump failure is extremely rare and if it was faulty, would show up from cold. If you have disconnected the coolant temp sender, how the hell was the code read clear? An open circuit coolant temp sender was would have come up at least.
  5. Re: mk 4 golf
    #15
    Feb 2009
    hi crasher,
    Thanks for putting a post up,
    First thing i did was take it to diagnostics, (motortek in doncaster)
    It was after that,when i removed the temp sensor.
    Do you have any advice?
  6. Re: mk 4 golf
    #16
    135 Post(s)
    2037 Post(s)
    The starter is a good possibility but I find they also cause poor cold starting. Analysing the hot cranking speed is quite difficult as you have to get the engine hot, disconnect the injectors (the easiest way to stop it firing up) and then crank it over on a good battery whilst entering the engine diagnostics and keeping it cranking whilst going into measuring blocks to observe the cranking speed, something that takes about 45 seconds of continuous cranking to achieve. I have used the recoding to auto box trick on these as the auto will fire at lower revs and if it starts well, then I change the starter.
  7. Re: mk 4 golf
    #17
    Feb 2009
    It may also be worth mentioning,
    - I swear it use to be a little dodgy on cold start up a few months back, but it would only happen the odd time,
    But two weeks ago i had the head removed (due to a broken glow plug) had the glow plug removed and threads cleaned.
    Head then refitted with new head gasket and cam belt.
    This was all done by my GF's brother who is an ex audi mechanic who qualfied a couple of years ago (so figured it was safe hands)
    It ran alright after the work was done, no hot starting issues. But i swear it still coughed occasionally on cold startup.
    --- just read your post cracker
    Sounds like cranking speed will be a nightmere to test. Im getting fed up with it all. Think it may be worth just changing the starter motor?
    have you found that to be the main cause of the problem?
    Matt
  8. Re: mk 4 golf
    #18
    Oct 2007
    You can check the temp sensor it can be checked in measured value blocks group 007.details of the temperature specifications are not possible.When the engine is cold the fuel,intake air and coolant temperatures must equate approximately to ambient temperature.If a temperature deviates noticeably,then the relevant sensor must be checked (replaced)
  9. Re: mk 4 golf
    #19
    Feb 2009
    crasher,
    can you tell me how to change the settings to an automatic?
    or is there a thread somewhere to do it?
    Matt
  10. Re: mk 4 golf
    #20
    135 Post(s)
    2037 Post(s)
    Do you have a registered copy of VAG-COM?
  1. More economical, more practical: The new golf plus bluemotion:
    Last Post: 15-08-2009, 07:48 PM
  2. Smarter, safer, greener: New golf estate unveiled
    Last Post: 25-05-2009, 04:19 PM
  3. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  4. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
    Last Post: 19-11-2005, 05:57 PM
  5. VOLKSWAGEN GOLF IS AGAIN EUROPE’S BEST SELLER
    Last Post: 03-03-2005, 09:43 PM
