Thread: mk 4 golf
Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 129
  1. Re: mk 4 golf
    #21
    Feb 2009
    i dont personally, but a friend of a friend has one, taking it around to his on monday night but i dont think he's had it very long.
    Im tempted to get one myself, as the lass has bough an a4 and id like to retro fit cruise.
    .... but this hot starting problem is really getting to me.
    Tried bumping it last night, it didnt want to start, however when we did it down a hill it chugged for a few seconds 3-5 seconds and then started...
    starter motor?
  2. Re: mk 4 golf
    #22
    134 Post(s)
    2022 Post(s)
    I can’t recommend you play with such in depth features without some experience, it is a safer gamble to just fit a new starter and see what happens.
  3. Re: mk 4 golf
    #23
    Feb 2009
    thanks crasher,
    i'll have to try the starter motor and see what happens...
    is that the usual suspect?
    ...if the starter doesnt work i'll be bringing it to you crasher if you can fit me in next week ?
  4. Re: mk 4 golf
    #24
    134 Post(s)
    2022 Post(s)
    You are looking at the middle of next month at the moment.
  5. Re: mk 4 golf
    #25
    Feb 2009
    Hi Crasher,
    Three weeks is going to be difficult for me, With needing the car for work and all.
    I think all i'd really be after is the diagnosing, if it was the fuel pump/starter motor i could get that changed easy enough by myself or my brother (ex audi mechanic)
    Could you fit me in any sooner if you just did the diagnosing?
    ..however if it was an injector, are they just a straight swap or do they need setting up?
    Plan is:
    - Tonight hook up to mates VAGCOM, test cranking speed. - Disconnect injector wiring, VAGCOM- Engine electronic, measured value block 1 ?
    - Heard i can also clamp the fuel return. Turn the engine off (quickly) and then try starting it. (with the idea of keeping the fuel pressure up)
    Hopefully these should shed some light on the starter or fuel pump. But after that i'd be stuck at to what else it could be !
  6. Re: mk 4 golf
    #26
    134 Post(s)
    2022 Post(s)
    Give Roy or John in the office a bell on 01159785740 and see if they can get you in sooner.
  7. Re: mk 4 golf
    #27
    Feb 2009
    Middlesbrough
    crasher you said about coding the ecu to automatic transmision to see if its the starte.. what happens if you leave it set for automatics?
    with out dissapointment you cant appreciate victory
  8. Re: mk 4 golf
    #28
    Feb 2009
    I've heard from another forum it can cause juddering between gear changes?
    Found out that this friend of a friend has genuine vagcom (£280) so I may look up how to do the automatic thing.....may
  9. Re: mk 4 golf
    #29
    Feb 2009
    tdi golf,
    i noticed a couple of months back you had warm starting problems, have you still not fixed it?
    From what i read you were going to change your starter motor?
  10. Re: mk 4 golf
    #30
    Feb 2009
    Middlesbrough
    yeh i was but i havnt got the money at tho moment.. i have changed my engine as the other one was down on compression and when i removed the head the pistons had hammer marks in them so looks as if it has been siezed before i bought it then they have freed it off and sold it.. but i found a engine with only 40k onit had been put it for scrappage the car was like new felt guilty taking it out :P but this engine is the same when its warm wont have it it always starts jus takes a bit of turning over compared to when its cold i tryed to fit the startermotor from my new engine but it was from a automatic so it wouldnt fit think they are different? think it might be the starter motor though as i put a new cambelt ect on it so its al timed up right..
  1. More economical, more practical: The new golf plus bluemotion:
    Last Post: 15-08-2009, 07:48 PM
  2. Smarter, safer, greener: New golf estate unveiled
    Last Post: 25-05-2009, 04:19 PM
  3. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  4. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
  5. VOLKSWAGEN GOLF IS AGAIN EUROPE’S BEST SELLER
    Last Post: 03-03-2005, 09:43 PM
