Thread: mk 4 golf
Page 5 of 13 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 129
  1. Re: mk 4 golf
    #41
    Feb 2009
    Done an auto scan on the car and it threw this up
    Address 03: ABS Brakes
    Controller: 1C0 907 379 D
    Component: ASR FRONT MK60 0103
    Coding: 0021505
    Shop #: WSC 00028
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Ross wiki says
    01314 - Engine Control Module: Check DTC Memory
    Possible Causes
    • Fault(s) stored in Engine Control Module
    Possible Solutions
    • Check Engine Control Module for Fault Codes
    Special Notes
    • Engine Control Module stored a Code which influences other Control Modules Functionality.
    • To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
    Not quite sure what this means and how it can impact on the car??
    Anyone got any ideas?
  2. Re: mk 4 golf
    #42
    134 Post(s)
    2021 Post(s)
    And what was the code in the engine memory or is that a hangover code from before?
  3. Re: mk 4 golf
    #43
    Feb 2009
    Havn't checked the engine control module yet, cos:
    a) i needed some food
    b) laptop batty was flat and
    c) im not sure how to check that specific function with VAGCOM !
    When i checked the engine there was no fault codes.....
    Any advice crasher?
  4. Re: mk 4 golf
    #44
    Feb 2009
    this is what VAGcom threw up.. i deleted the scans with no faults
    Chassis Type: 1J - VW G/J/B Mk4
    Scan: 01,02,03,08,16,15,17,19,22,35,46,56
    Address 01: Engine
    Controller: 038 906 019 CJ
    Component: 1,9l R4 EDC G000SG 1086
    Coding: 00002
    Shop #: WSC 00028
    No fault code found.
    Readiness: N/A
    Coding: 0021505
    Shop #: WSC 00028
    1 Fault Found:
    Address 46: Central Conv.
    Controller: 1J0 959 799 AH
    Component: 4U Zentral-SG Komf. 0001
    Coding: 04096
    Shop #: WSC 00028
    2 Faults Found:
    00943 - Heated Exterior Mirror: Driver Side (Z4)
    35-00 - -
    00944 - Heated Exterior Mirror: Passenger Side (Z5)
    35-10 - - - Intermittent
    Address 56: Radio
    Controller: 1J0 035 186 D
    Component: RADIO SON 0003
    Coding: 01403
    Shop #: WSC 00028
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    07-10 - Signal too Low - Intermittent
    End --------------------------------------------------------------------------------------------------
  5. Re: mk 4 golf
    #45
    Feb 2009
    Right, think the engine control module memory is just intermitten because i had the battery off for two days.
    Did a test last night: i clamped the fuel return hose and then quickly turned off the engine.
    When i when to restart:
    1st time - straight away
    2nd time - much better not but instant.
    Have a feeling it could be the fuel pressue. Going to change the one way valve on the filter first, (because its cheap, quick and easy) and if that doesn't fix it.
    I have a spare tandum pump that im going to fit to see if that helps with the pressure.
  6. Re: mk 4 golf
    #46
    Feb 2009
    well new air mass meter and new valve in the fuel filter.
    Nothing.
    Took it for a 15minute drive, county lanes up the odd hill and i could only manage 38.5 mpg,
    could this be because the car trying to pass all the tests and the ecu is 'learning' or could something else be happening?
  7. Re: mk 4 golf
    #47
    Feb 2009
    print out from VAGCOM
    Looks like the injector timing is within range...?
  8. Re: mk 4 golf
    #48
    Aug 2009
    Stoke on Trent
    Hi There,
    try the relay rail underneath the steering wheel, the wiring for the diesel relay goes faulty cost approx £15 from VW. I had a similar problem with my Golf only it wouldn't start in the morning. Seems to be a common problem with VW Golf's
  9. Re: mk 4 golf
    #49
    Feb 2009
    changed relay 109 and temp gauge...hasnt helped
  10. Re: mk 4 golf
    #50
    Can you post a reading from measured value blocks13 and 18 with the engine idling? and blocks 10 and 11 in 3rd gear with aprox 3000 rpm
  1. More economical, more practical: The new golf plus bluemotion:
    Last Post: 15-08-2009, 07:48 PM
  2. Smarter, safer, greener: New golf estate unveiled
    Last Post: 25-05-2009, 04:19 PM
  3. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  4. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
  5. VOLKSWAGEN GOLF IS AGAIN EUROPE’S BEST SELLER
    Last Post: 03-03-2005, 09:43 PM
