Hi all,
I've got a 1996 A4 2.6 V6 (which I recently bought). Last week it blew the side-part of the right rear combined brake/tail bulb, which I changed. However, now none of the tail lights work on either side (all fuses and bulbs are ok). The brake part of both bulbs works fine. Any clues? Furthermore, the Airbag warning light now stays on for two minutes after I turn the ignition on. Looks like an electrical problem. I hate electrical problems! Any ideas from someone who had this before?
In addition, does anyone know what the light in the middle of the left rear cluster is? It comes on when I turn the lights on but
a) there is no way to replace it (it is not in the removable part with all the other bulbs, but the whole cluster needs to be removed)
b) there is a wire going into the equivalent position on the right side but no light comes on. I cannot see if there is actually a bulb there or not and do not want to dismantle the thing. Is there a bulb supposed to be in there that has gone?
Many thanks!
