Thread: ABS and Traction Control Warning lights
  1. ABS and Traction Control Warning lights
    May 2007
    Central Scotland
    Hello,
    Just wondering if any of you guys have come across this, about 6 months ago i had to replace the Flywheel and clutch on my 2002 Audi A4 1.9 TDI. ever since then i have had 2 warning lights appear whilst braking, these stay on until i switch off the engine . This does not seem to affect the actual ABS or Traction controls. it would be great if anyone could help.
    tinyman
    Oct 2005
    Lutterworth
    AFAIK having the ABS light on means that it is disabled.
    Are you say that yours is working under those circumstances?
    I suggest to have someone read any fault codes.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    May 2007
    Central Scotland
    thanks for the reply, does not feel any different when the lights are on or off and still get vibration through the pedal, but have found a thread which details my problem and it was fauly brake light switch, so will be taking it along to me mechanic to get it checked out.
    Thanks again.
    tinyman
  1. ABS / Traction control light
    By Effect in forum Audi A3 - Archive Topics
    Last Post: 13-11-2007, 12:12 AM
  2. S3 Traction control
    By rdj_s3_quattro in forum Audi A3 - Archive Topics
    Last Post: 05-08-2007, 09:28 PM
  3. ASR/Traction Control
    By Cara2007 in forum Archive posts
    Last Post: 01-04-2007, 09:47 AM
  4. ABS+Traction Control Lights Intermittent
    By metallicabmw in forum Passat - Archive Topics
    Last Post: 16-02-2007, 12:06 PM
  5. Passat ABS/Traction Control Sensor
    By JRPdark in forum Passat - Archive Topics
    Last Post: 26-01-2007, 07:56 PM
