Hi - I'm trying to find where i can get the plastic fasteners that hold the roof lining in place on my T4. I know that the main dealers do them but is there a cheaper aftermarket option? They are a cr*p design where you use a hex socket that instantly rounds off, i have had to drill most of them out.
Also, I've got an old Laser Line alarm installed and it has another siren in the rear that i had disconnected by a local alarm installer. All he did was cut the live wire (!) which seemed to do the trick. I know need to remove the whole siren and it's got the earth and two othe wires still connected. One of the other wires is marked 12v Ignition. If i cut this am i gonna get a) a shock and b) the alarm going off.
