Thread: Heater/Blower stopped working
Results 1 to 10 of 15
  1. Heater/Blower stopped working
    scottjay86 Guest
    I just got my car back from its MOT fix and discovered the blower/heater does not come on at all anymore. Its a real pain as the window constantly mists up in this weather and now takes forever to clear, driving with the passenger window down.
    I'm fairly sure one of the fuses has blown. Any idea which one it would be. I don't want to go back to the mechanic for him to charge me an arm and a leg for something I can replace myself.
  2. Re: Heater/Blower stopped working
    Oxted
    Fuse F6 is the one.
    Should be a sixth from the left on the fuse box.
  3. Re: Heater/Blower stopped working
    scottjay86 Guest
    Cheers.
    Never bought a fuse before, do the likes of Halfords do them?
  4. Re: Heater/Blower stopped working
    Oxted
    Yeah, they do. They'll probably sell you a set. They're only a few quid though.
    Check the fuse first, make sure its that. Basicly, there will be a thin bit of metal (usually inside a bit of clear plastic, but mine aren't). If its broken, the fuse has blown, if not its something more serious.
    I had the same problem myself, and it turned out to be corrosion on the resistor....
  5. Re: Heater/Blower stopped working
    Oct 2009
    Blackpool, uk
    if its not the fuse it maybe the same problem i had with mine the plug which goes in to the risistor had melted .
  6. Re: Heater/Blower stopped working
    Oxted
    whats the story scottjay86?
  7. Re: Heater/Blower stopped working
    scottjay86 Guest
    I've checked all the fuses and they seem to be grand. Is the resistor thing hard to fix?
  8. Re: Heater/Blower stopped working
    Oxted
    Well, it somewhat depends on your skill level and the tools you have avaliable...
    Getting to the resistor is not too dificult. You need to take the glovebox off. In my cabrio, its just 5 screws.
    The resistor is clipped into the back of the exposed area, next to the blower. It has two power clips connected to it. A 4way from the switch and a single pole to the blower.
    If you diconnect the clips and remove the resistor you can have a good look at it. I would suggest using a ohm-meter to see if its working.
    Then use a volt meter to see if the output from the switch is working ok.
    It seems that it's quite common this component to be bust (it gets very hot), in my case the contacts were corroded and I had to clean them up with a needle file.
    I would suggest you get a haynes manual and read the relivant bit before you attempt anything.
    Hope that helps.
  9. Re: Heater/Blower stopped working
    S.Wales
    Yup, i got the same prob, water got to resistor, fixed it for now, but need
    to find where the water came in.
  10. Re: Heater/Blower stopped working
    scottjay86 Guest
    Update
    Was driving home the other night, heard a click, thought *** that, then felt the magic of heat comnig out of the vents.
    Never done anything to it, the blower just started working as quickly as it stopped. Hasn't cut out for a few days now so fingers crossed it stays working.
  1. My internal heating/fan has stopped working
    By tayls4wales in forum Golf MK4 - 1999 - 2004
    Last Post: 07-11-2009, 12:50 PM
  2. brakes stopped working coming upto the lights!
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 04-05-2009, 10:02 AM
  3. remote stopped working
    By macleod in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-07-2008, 09:05 PM
  4. Near SIde Main Beam STopped Working
    By markb1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2007, 10:21 AM
  5. Rear Wiper stopped working
    By Slur in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2007, 03:38 PM
