Thread: 2.5D (AKN) Timing belt or belts?
  1. 2.5D (AKN) Timing belt or belts?
    Aug 2007
    Wicklow
    I've been doing some searching on timing belt kits for my 2001 AKN 2.5D A6 as I don't trust the history that it was done 10k ago.
    One supplier is showing a kit at around £70 (marked 87 teeth), but they also have a one at £320 (marked 207 teeth).
    Another is showing a kit (p/n: 059198119B) for £150 that seems to have two belts in the kit already.
    So, two questions:
    1) Does the car have two timing belts?
    2) On a wider note, what else would be a recommended change once the front is off the car? Normally I would do the water pump with the timing belt but from what I've seen it might be a good idea to change the thermostat, water pump, the chain on the oil pump, and possibly the sprocket/follower for this chain.
    Any suggestions/help? The car is just coming up on 80,000 miles.
    Thanks.
  2. Re: 2.5D (AKN) Timing belt or belts?
    Jun 2006
    UK, Mids
    There is one timing belt, one fuel injection pump belt (the cheaper one) and then auxiliary belts for charging and air-con. It is very wise to do the water-pump and maybe thermostat too.
    Audi A8 - 2015 - 3.0TDI
  3. Re: 2.5D (AKN) Timing belt or belts?
    Service postion bolts, Belts 2 toothed. Belt tensioner, for both belts, Water pump and pre-tested thermostat. Locking tools Vag-com to dynamically time the injector pump, a special tool for adjusting the pump timing/tension, a workshop Manual and 2 spare days and a box of plasters for cuts and bruisers. Why do you think the belt has not been changed. Regards Peter
  1. Court Hearing - Information required...
    By motyourcar in forum Chat - Anything with wheels
    Last Post: 17-08-2011, 09:31 PM
  2. Timing belt renewal 1.9 TDI ASZ (PD)
    By butljon in forum Golf MK4 - 1999 - 2004
    Last Post: 12-08-2011, 08:37 AM
  3. Guide S4/A4 V6 Cambelt
    By spellmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 05:23 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
